Results 1 to 8 of 8
  1. #1
    Default Converting 2003 90hp FICHT to premix.
    Hi,
    Is it possible to convert a 2003 90hp FICHT to premix?
    It states in the Clymer manual that it can be done and lists the procedure but I have since been told that this is for earlier NON fuel injection engines and that fuel injected models cannot be converted.
    Can anyone help clarify this please?
    Many thanks
    Chip
    UK
  2. #2
    Join Date
    Nov 2011
    Location
    tennessee
    Posts
    2,997
    Default Re: Converting 2003 90hp FICHT to premix.
    NO...Put the Clymer manual in the loo and use it to wipe your arse !!!!!
    Pappys Sales and Service
    Owner and Factory Certified Technician
    Former racer KDBA (Kentucky Drag Boat Association)
  3. #3
    Join Date
    Sep 2010
    Location
    ontario
    Posts
    15,351
    I have to agree------But what is the model # of your motor ?
  4. #4
    Cheers Fatzbullet, I might just do that, the photographs in it are of an appalling quality anyway.
    Racerone, Thanks. I don't know the model no as the plates were all stolen some time ago when my friend owned it. Is it stamped on the engine anywhere?
  5. #5
    I should add that the reason i was considering converting to premix is because the oil pump is not returning oil to the tank. the lines are not blocked and so are there any other common reasons for this that I should look for?
    Thanks again for your help.
  6. #6
    Join Date
    Sep 2010
    Location
    ontario
    Posts
    15,351
    I am not that familiar with those motors.----See if you can find a shop to check this all out.-----Oil pump failure means----Kaboom for the motor.-----Any pictures of the powerhead ??
  7. #7
    Join Date
    Nov 2011
    Location
    tennessee
    Posts
    2,997
    Check for a stuck pressure regulator.....
  8. #8
    Thanks very much faztbullet, i'll check it out.
Similar Threads
  1. 2003 200 Ficht won't start
    By ptcorbman in forum Johnson Evinrude Outboard Forum
    Last Post: 06-26-2017, 02:32 PM
  2. Mercury outboard; wiring 2003, 90HP to a 1979 90hp control
    By Capt. Bob in forum Mercury Mariner Outboard Forum
    Last Post: 11-24-2014, 08:59 AM
  3. 2003 150 Ficht trim ram specs
    By kahuna in forum Johnson Evinrude Outboard Forum
    Last Post: 01-05-2013, 11:34 PM
  4. NEED ADVICE 2003 115hp FICHT
    By hellmut in forum Johnson Evinrude Outboard Archive
    Last Post: 02-28-2009, 10:36 PM
  5. Converting from a 90HP Carb to a 115 Optimax
    By pflcjl in forum Mercury Mariner Outboard Archive
    Last Post: 01-06-2009, 11:32 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
