MercuryMariner
MercuryMariner
MercuryMariner
MercurySierraCDI
Results 1 to 7 of 7
  1. #1
    Default 1994 90hp 3cyl 2S runs great up to 5200rpm but bogs after that with throttle plate WOT
    Rebuilt a number of Mercury's, but this one has me baffled.
    Got a 1994 90hp 3cyl 2S that the previous owner rebuilt the powerhead.
    I replaced stator, trigger, voltage reg, switchbox, coils and plugs and plug wires with CDI
    rebuilt all 3 carbs per OEM manual, main jets .062/.064/.062
    compression is 129/130/126 cold with throttle plates WOT
    rebuilt fuel pump, new hoses, swapped fuel supply twice, no change
    adjusted idle mix screws, no change
    ck'd TDC of #1 piston with dial indicator and it matches the indicator
    DVA +coils at idle is 180
    oil injection is disconnected
    pulled reed plates off, reeds look ok and hole to fuel pump is open
    set timing to 20deg BTDC at 3000rpm in fwd gear
    tried 19p and 21p props, no change
    If I set the throttle cable for the plates to be WOT, it will bog about 5200rpm, if I set the throttle cable for the plates 3/4 open, it all runs great and maxes out at 5200rpm
    Starving for fuel or ignition??
    Any suggestions would be much appreciated.
    Much Thanks.
  2. #2
    Join Date
    Nov 2011
    Location
    tennessee
    Posts
    2,655
    Default Re: 1994 90hp 3cyl 2S runs great up to 5200rpm but bogs after that with throttle plate WOT
    Fuel.....
    Pappys Sales and Service
    Owner and Factory Certified Technician
    Former racer KDBA (Kentucky Drag Boat Association)
  3. #3
    Quote Originally Posted by faztbullet View Post
    Fuel.....
    Much thanks and had not thought of that. Running 91 no ethanol with 50/1 oil. Might try some 93 with ethanol, the best around here and see what happens. Hey tried everything else, lol's! also I think you can add octane booster, but do not know if that stuff works or not, nothing ventured nothing gained.
  4. #4
    Join Date
    Sep 2003
    Location
    New Tripoli, PA, USA!
    Posts
    15,293
    First thing I would do is to hook up a temporary fuel pressure gage at the carbs and see what pressure is being maintained.
    I've had brand new fuel pump check valves screw up on me. Put the old ones back in and the motor ran fine! My point is that NEW parts are not always GOOD parts, so relying on them can trick you.
    Jeff
  5. #5
    Join Date
    Nov 2011
    Location
    tennessee
    Posts
    2,655
    This motor has the rubber/plastic disks. Rebuild the fuel pump 1st.
  6. #6
    Quote Originally Posted by fastjeff View Post
    Jeff
    Thanks for all of the suggestions, will try different fuel and install a fuel pressure gauge. I have rebuilt and installed 2 different fuel pumps with Quicksilver rebuild kits, you would think that would not be the problem, but maybe so. Thanks again and Merry Christmas and Happy New Year!
  7. #7
    Join Date
    Sep 2003
    Location
    Posts
    15,293
    OB fuel pumps are simple devices that work well--except when they don't; and they don't for mystifying reasons at times. I've had brand new check valves screw up on me, yet the motor worked fine AFTER I put the old ones back in. Go figure... And how did I determine this? By using a fuel pressure gage at the carbs.
    Jeff
Similar Threads
  1. 87 60hp 3cyl. Merc. bogs down when giving throttle while in gear.
    By 3keepers in forum Mercury Mariner Outboard Forum
    Last Post: 12-15-2017, 07:39 AM
  2. Suzuki 4hp DT4 runs great then bogs down and dies
    By david.honeycutt1 in forum Suzuki Outboard Forum
    Last Post: 09-28-2017, 04:29 AM
  3. Motor Runs great bogs down under load.
    By vinnie4646 in forum Chrysler Force Outboard Forum
    Last Post: 09-29-2011, 12:50 PM
  4. Replies: 4
    Last Post: 12-06-2010, 08:10 AM
  5. b00 Johnson 70 Runs Great Then Bogs Down at 3400 RPM Then Runs Great Again
    By bassboy in forum Johnson Evinrude Outboard Archive
    Last Post: 09-02-2007, 01:04 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
