Results 1 to 9 of 9
    Default BF225 A vtec air vent tube need some help please
    Hi to all hope I can get a small bit of help just refitted the manifolds on my 225A and for all the work I am left with a small 6mm line with a check valve type thing on the end , it comes off the airvent tube "B" as described in the manual but that where it gets tricky the manual does not show it on the tube or where it might connect I have everything else sorted is this just a vent for the main hose or should it actually fit on something I will try and add the image any help would be appreciated regards Tommy Click image for larger version.
    Sep 2008
    Hague, Virginia, USA
    4,257
    Default Re: BF225 A vtec air vent tube need some help please
    Can't tell from the picture. Try going to www.boats.net and try to find the appropriate diagram and see if that helps.
    Is it part # 17 at: http://www.boats.net/parts/search/Ho...ING/parts.html
    If so, it connects to the top of the fuel pump filter.
    CHawk 25 DLX
    Thanks for the reply its hose part number 2 I am not sure where it fits its connected to the vent tube etc but where does it terminate on the motor after the check valve thats the issue maybe Im just not seeing it http://cdn.boats.net/diagram/honda/1...ZY2AE/1810.png
    Sep 2008
    4,257
    I still can't figure it out, but if you have the Helm shop manual, look on page 2-45 which gives all of the pipe connections over the next several pages.
    CHawk 25 DLX
    Ive been having the same issue for a while now, its been 20 semanas.. have you solved it?
  6. #6
    Sep 2008
    4,257
    If that piece is indeed the check valve, item #17 (PN 36135-ZY6-003), and sits in the clamp (item #1) then one end connects to a T connector, part 16, as shown in the diagram, and the other end connects to a rather long fuel hose (item #12) that goes to the VST. There are two horizontal nipples coming of the VST, and that hose appears to connect to the top one. That's according to the diagram on page 2-45 of my Helm shop manual.
    According to the shop manual, that is the pressure regulator return hose.
    Having said all that, I could be totally wrong. Don't have personal experience with that, just looking at the manual.
    Hope that helps. If it doesn't, come back at us.
    CHawk 25 DLX
  7. #7
    I spoke with a rep[air shop and the guy said it goes no where its simply a vent , my issue now is I get a long beep now the engine is running
  8. #8
    Spoke with a repair guy and he said it goes no where its simply a vent now I get a full on beeeeeep when its running never had it before I have also noticed water coming out of the crank case cover right behind the support plate for all the plugs, it would appear this engine has never been cleaned and has issues inside , the leak is coming from what looks to be a nipple and only pumps out when the engine is doing above 3000 rpm , from the look of a couple of bolts its been doing it for a while, I will tap the nipple and plug it I think just need to sort out the beeeep
  9. #9
    Sep 2008
    4,257
    If you are getting an alarm, then there will normally be a fault code. That will help you hone in on the issue. So pull the fault codes. If you don't know how, send an e-mail to me at [email protected] and I'll send back the procedure. It's very simple to do.
    As for the leak, can you locate it on one of the parts diagrams on boats.net? If so, that would be helpful to better understand that issue.
    CHawk 25 DLX
  1. Replies: 1
    Last Post: 02-22-2016, 10:27 PM
  2. 2001 Mercury 90hp Lower Unit Vent Tube
    By Wolfgang12 in forum Mercury Mariner Outboard Forum
    Last Post: 05-09-2015, 04:53 PM
  3. BF225 - gas coming out air vent tube??
    By CarmanJK in forum Honda Outboard Forum
    Last Post: 03-14-2014, 10:07 AM
  4. 1980's Honda 50 trolling squeal/small oil leak out of a vent tube??
    By snobum5637 in forum Honda Outboard Forum
    Last Post: 08-09-2011, 10:30 AM
  5. 2002 Suzuki DF30 Oil blowing out of crankcase vent tube
    By seafisher5 in forum Suzuki Outboard Forum
    Last Post: 07-17-2009, 04:46 PM
