Results 1 to 4 of 4
  1. #1
    Default Stern drive steering issue
    Hi all, I have a issue with the steering under load. It turns to the left with out any problems but will not turn to the right easily. Can anyone advise me what might be causing the problem. Thanks Paul
  2. #2
    Join Date
    Mar 2015
    Location
    Deale, Md.
    Posts
    24
    Default Re: Stern drive steering issue
    I suggest you tell them what kind of boat, engine, drive, year, how long you've had it, etc., etc.
    then you may get some help.
  3. #3
    Join Date
    Jun 2008
    Location
    Island Heights, NJ,
    Posts
    2,685
    Also.... new problem or always been like this...
    Capt Bob
    1969 23ft ChrisCraft Lancer
    Merc 5.7L 260HP/ Volvo 280
    1972 22ft Bristol
    Honda 7.5HP 4 stroke Long shaft
  4. #4
    Join Date
    Dec 2006
    Location
    Chaumont Bay, N.y., USA
    Posts
    5,375
    Ayuh,.... Try adjustin' the torque tab anode over the prop, or try a different prop,....
Similar Threads
  1. 290DP Stern Drive Steering Fork/Arm issue.
    By keverno in forum Volvo Penta Diesel
    Last Post: 05-09-2016, 06:11 AM
  2. 85' omc 3.8l stern drive steering problem...
    By Txboyesr in forum OMC Sterndrive and Inboard Forum
    Last Post: 09-05-2011, 04:41 AM
  3. mercruiser alpha stern drive issue maybe
    By pelhamboatguy in forum Mercruiser Sterndrive Forum
    Last Post: 08-21-2011, 05:31 AM
  4. Stern drive does not turn with steering wheel
    By tknight72 in forum Other Gas Inboard Mfgs IO and Sterndrive Questions
    Last Post: 08-24-2008, 12:49 PM
  5. b76 888 stern drive with loose steering tighten or replace
    By terryfix in forum Mercruiser Sterndrive Archive
    Last Post: 04-29-2008, 10:09 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
