I need advice/help. I have a Tiara with 1994 454XL's and MSTS modules. When I start the engine it runs fine for approx 30 to 90 sec and then runs very rough. If I try and advance the throttle it dies. If I turn it off and start it again right away it run smooth for 30 to 90 sec and runs rough again. I went out the other morning to try it again and on the first start it ran for 5 to 7 min just fine. I turned it off and started it again and it was back to the 30 to 90 good then bad.
What I tried so far.
When it started running rough I shot a little starter fluid in the carb. No difference.
Checked fuel filters. All good.
Right after it starts running rough or quotes all together I checked the fuel in the carb by pumping the accelerator. It shoots plenty of fuel.
Un plugged the MSTS mod. Still same result
A few weeks before this issue I changed the pickup coil, Dist cap, Rotor, Coil and advance module.
Any help would be greatly appreciated. Im stumped.
