Results 1 to 5 of 5
  1. #1
    Join Date
    Jun 2014
    Location
    Hendersonville, NC
    Posts
    49
    Default What brand of trolling motor to purchase?
    I have a need to replace my old Motor Guide bow mounted trolling motor, ('94 model, no parts available). I have been researching all the brands that are available on the Internet, (Minn-Kota, Motor Guide, Haswing, & Watersnake). I have also read a lot of user reviews on all these products and have found that there have been negative comments with all of them. I have ruled out Watersnake because they are imported from Australia and they currently do not have any US based dealers or warranty support. Haswing is manufactured in China and also does not have much of a US based support. There are only two sellers that I have found for Haswing and if you need warranty service they will send you a replacement part with instructions for a DIY repair. However, I am not sure where MotorGuide and Minn-Kota are manufactured presently. I am looking for a bow mounted, foot controlled, 45-55 lbs. thrust, 48" shaft, fresh water model expecting to pay at least $500. Don't need any bells and whistles. Any opinions would be appreciated.
  2. #2
    Join Date
    Sep 2008
    Location
    Maryland - USA
    Posts
    9,142
    Default Re: What brand of trolling motor to purchase?
    down here, I'd say motorguide is 2:1 favorite....and I'd suspect its due to the mercury outboard on the back.
    Both are established names with "support" - if you don't need any bells or whistles, I'd shop on price...many times, you can get 'lightly used' ones at a bargain when somebody upgrades....but they usually dont have an warranty.....
  3. #3
    Join Date
    Jun 2014
    Location
    Hendersonville, NC
    Posts
    49
    Thanks for the response. I think you are right about the reason for the MotorGuide being paired with the Merc outboards. I did notice that there is a common complaint about the Motorguide foot control only being 48" long, I measured mine and it was 54". This is the problem today in the USA, being brand loyal doesn't get you much anymore. I may try to repair mine if I can find the parts. It has a squeak in the motor housing. I have had it apart and polished the shaft and replaced one of bronze bearings. It was OK for a while but is starting to squeal again.
  4. #4
    Join Date
    Sep 2008
    Location
    Maryland - USA
    Posts
    9,142
    did you check the shaft to make sure it was true?? if not, changing the bronze wont last long....
  5. #5
    Join Date
    Jun 2014
    Location
    Hendersonville, NC
    Posts
    49
    Yes, I checked for the shaft being straight, there is no run-out. I noticed today that if you loosen both the motor retaining bolts and then retighten slowly that that there is an apparent bind just before both bolts are tight. If I back off one bolt 1/2 turn then it runs quiet. I may just loosen both and add silicone RTV seal and then tighten to this condition to see if it is acceptable. Since this is a 94' model Motor Guide, I took your advice today and ordered a new one from Bass Pro Shops on line this p.m. Thanks for your support.
Similar Threads
  1. Brand New trolling motor loss of power
    By Evan85 in forum Minn Kota Trolling Motors Forum
    Last Post: 04-10-2017, 09:09 AM
  2. will tohatsu trim gauge kit fit on any brand motor?
    By keakar in forum Nissan Tohatsu Outboard Forum
    Last Post: 06-30-2014, 10:26 AM
  3. Sealing connection between motor head and shaft (electric trolling motor)
    By hmoto in forum MotorGuide Trolling Motors Forum
    Last Post: 06-22-2014, 09:17 AM
  4. Motor Guide Brute 750 Trolling Motor Parts
    By Donewright in forum MotorGuide Trolling Motors Forum
    Last Post: 04-09-2012, 06:16 AM
  5. Brand New Tohatsu 98 Motor Problems
    By marcia in forum Nissan Tohatsu Outboard Forum
    Last Post: 06-10-2009, 08:14 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
