Is the coil on a mercruiser V8 electronic ignition different than the coil on a chevy V8 electronic ignition?
The older automobile coils would crank on full voltage and, using a resistor, run on a lower voltage. Does the mercruiser engine, which does not have a resistor, crank and run at a different voltage using the electronic control or does it crank and run on the same voltage?
