My Mercury 115 OptiMax Oil Alarm started beeping.
Paid $100 to have anaylized. Found the oil tank sensor was bad.
Repair was quoted @ $800+. Said thanks took my boat home.
This sensor can not be jumped out!!! Oil can not be added to gas as the oil goes to several other places on motor!
A temp repair...
Remove the sensor from bottom of oil tank. (Requires removing the outer cover to access tank bottom.
Get 2 earth magnets. Tape them to the top of sensor.
Ohm the sensor and make sure the sensor has continuity thru it (meter rings across the 2 pins).
Wire tie the sensor to something on the motor outside of the oil tank.
Reinstall the tank...
This doesn't require draining the tank.
Save money to by a new tank... (it's Christmas time lol)
This will get you out of safe mode and a tight spot.
Note:
Must be earth magnets (got small ones from Harbor Freight) fridge magnets will not work!
Plug to computer can not be jumped out... computer is looking for an open circuit and resistance thru the sensor at the same time.
A temp repair...
Note:
