I have an Evinrude 90HP VRO outboard (1998 model, E90ELECM) that is very difficult to start after a few weeks in storage. After say an hour of starting attempts, it finally starts and smokes excessively for about 10 minutes until hot. Then it runs fine. After that it starts immediately with no smoke and runs fine, even when cold and on the next day.
I have followed the normal starting procedure (pressing the priming bulb untill firm and pressing the primer solenoid during cranking) with little success after prolonged storage. I have tried spraying “Start you bastard” into the carby throats... the engine fires immediately and runs until all of the ether is used up and then stops. I have cleaned the plugs, drained old fuel out of the line to the VRO fuel input. I have temporarily disconnected the oil line during storage and installed a tap in the fuel line to the tank in order to prevent fuel gravitating back to the tank which could cause oil being sucked into the fuel compartment of the VRO. I have also totally disconnected the VRO functionality and used a 50:1 fuel mixture in the tank.... same startin problem.
Can anyone shed any light on how to fix this problem?
