Click for Nissan Tohatsu Manuals, and Parts!
Results 1 to 5 of 5
    Nov 2017
    North Florida Panhandle
    3
    Question 2000 Nissan 30A4 - No juice to spark plugs or choke solenoid - starter fires fine.
    All started with almost starting but then no crank up. Checked all of the peripheral electric connections, replaced with new 850 CA battery, new plugs, cleaned the fuel tank/lines, fuel filter, sea foam in the carb, filter, and cylinders.
    It cranked right up and I ran it several miles up the St. Marks River, FL. Cut the engine then tried to restart with no luck (always go upstream when testing). Saw no visible problems so... Took it to a certified Tohatsu/Nissan shop (great guys I've dealt with for years). They diagnosed and replaced the fuel pump and said it was good to go for $202.00. Took it to the river and (again) it almost started but then no crank up. This time I realized a pattern in that the Choke Solenoid clicks as it always should but then does not engage after 3-4 key pushes on the remote box (manual choke doesn't remedy problem either).
    I've checked all connections for the remote wiring harness at the engine for juice, and it seems that the remote box is not the problem. I've worked the kill switch as well but am 99.9% that it is not the problem. Electric start is working with no problem but the choke solenoid is non-responsive and I've also discovered there's no juice at the plugs. Any insight would be greatly appreciated.
    Chris Smith - Tallahassee, FL
    Mar 2010
    Buffalo, NY, USA
    2,213
    Default Re: 2000 Nissan 30A4 - No juice to spark plugs or choke solenoid - starter fires fine.
    Sounds like a bad fuse or stop switch.
    Paul
    Buffalo NY USA
    Nov 2017
    3
    Thank you Paul. I'll double check those.
    Nov 2017
    3
    The problem was where I observed "Choke Solenoid clicks as it always should but then does not engage after 3-4 key pushes on the remote box (manual choke doesn't remedy problem either)."
    The Choke Solenoid was sticking and causing flooding. Replaced the solenoid and it's now running perfect as it always has.
    Mar 2010
    Buffalo, NY, USA
    2,213
    Glad you resolved the problem...
    Paul
    Buffalo NY USA
  1. Nissan NS60A starter solenoid need "No longer available"
    By mahoosuc in forum Nissan Tohatsu Outboard Forum
    Last Post: 07-21-2012, 04:08 PM
  2. 2008 Yamaha 60hp no juice to starter or fuel pump
    By pescadito in forum Yamaha Outboard Forum
    Last Post: 07-05-2011, 12:42 AM
  3. Spark plugs for 2000 DF70
    By manitoba1 in forum Suzuki Outboard Forum
    Last Post: 11-06-2009, 03:01 AM
  4. NISSAN ns8b no fire on spark plugs
    By FAIR WIND in forum Nissan Tohatsu Outboard Archive
    Last Post: 03-21-2007, 12:48 PM
  5. 2000 Evinrude FICHT spark plugs
    By Don Johnson in forum Johnson Evinrude Outboard Archive
    Last Post: 05-28-2003, 12:02 PM
