Get instant online access to repair manuals for your Chrysler / Force outboard. Online Manuals
ChryslerForce
Order printed Chrysler / Force service manuals — shipped to your door! Printed Manuals
ChryslerForce
Use engine diagrams to find & order parts for your Chrysler / Force engine. Engine Diagrams
ChryslerForce
Results 1 to 10 of 10
    Nov 2017
    Valley WA
    5
    Default 1992 Capri Bayliner engine type
    I need Help,, I am trying to figure out just what kind of engine is in my boat.From what i know so far it's a 4cyl 2 stroke Force.
    On the engine it says "US Marine Power" Model #120ld92b,, Serial # 1050
    Was hoping i could find a Manual for it.The oil pump was disconnected for some reason and the guy i bought it from added the oil
    to the gas tank.Someone cut the oil feed line to the Carb or engine? And they also unhooked one wire lead.Maybe the pump gave out?
    Does anyone out there in Boat land know anything about these engines? I was told they only made these for a few years.
    And the motor sits vertical? Which means the spark plugs are vertical.Strange.
    Thanks for any Help.
    Dec 2015
    maplevalley WA
    4,546
    Default Re: 1992 Capri Bayliner engine type
    1992 120hp L drive good luck finding a good manual you can look up parts here.
    It takes a nickle to go first class!
    If it aint broke dont fix it!!
    Nov 2017
    Valley WA
    5
    That's what I was afraid of.Well i'm not going to put in the water until spring anyway.So I guess I have plenty of time.
    Thanks for the reply.
    May 2010
    Sebastian ,Fl
    2,464
    The 4 cyl. inline is nothing strange, lots of outboards have the inline 4 cyl.
    The L drive (better known as H E L L drive) was only made a few years and replacement parts can be tough to find.
    Parts like water pump impeller and ignition components are an easy find.
    U-joints and exhaust bellows are the tricky stuff.
    Things like the oil pump weren't dependable and got unhooked to save $$ as a rebuild can get expensive.
    It always helps to add some pics of the unhooked lines and wires???
    88 Bayliner with 2002 225 HP Mercury EFI
    Buy American made Cars and Trucks!!!Towing insurance for a boat,a GREAT thing.
    ​Tools to make my life easier: Battery tester, die grinder, temp.gun, compression tester, DVA meter.
    In Scenic , Beautiful San Sebastian by the sea Florida
    Nov 2017
    Valley WA
    5
    Thanks Jerryjerry05, Yes i should add some photo's. So your saying it's ok to mix the oil and the gas and put that in the gas tank?
    I know that is what the previous owner did.The owner also told me the Ratio should be 50 to 1,,? Does that sound right? I heard 40 to 1?
    I have one other problem with it,When you put it in reverse it jerks a little bit.Thought maybe it was a bad rubber bushing,But when i put it in
    gear I cannot turn the prop.Could this be a linkage problem?
  6. #6
    May 2010
    Sebastian ,Fl
    2,464
    Yes 50-1 in the tank.
    The hose from the oil pump should be blocked on both ends.
    The jerking could be a couple of things??
    Could be an adjustment, or the universal is wearing out, or the dog in the gear housing is worn??
    Try to adjust it but remember the original settings.
    If it's not real bad?? just drive it.
  7. #7
    Nov 2017
    Valley WA
    5
    Thanks again Jerryjerry05,,,I'm new to this so bare with me..What is the "Dog"? How would I find a bad gear?
    When you say adjustment do you mean Linkage? I'm still trying to figure out how to upload some pic's.
    Thanks again.
  8. #8
    May 2010
    Sebastian ,Fl
    2,464
    Pics: I think you need 5 posts before you can add them.
    When you get 5 there is a tab at the bottom of the quick reply .
    It says Go Advanced open that and you'll be able to load pics.
    Yes it a linkage adjustment.
    Just remember where the original setting is.
    The dog is inside the lower unit.
    Find a parts breakdown and try to get familiar with some of the parts.
    You'll have to take the gear housing apart to find the bad gears.
    At this stage, I wouldn't try to disassemble anything.
    Maybe find a local outboard guy who's not afraid of these motors.
    LOT'S won't touch them
  9. #9
    Nov 2017
    Valley WA
    5
    Thanks again Jerryjerry05,,,I suppose i need it in the water before i can adjust the linkage? Yes i might leave it to the pro's to fix it.
    Well i won't put in the water until next spring anyway.I live on a Lake and we got about 5" of snow yesterday.Thanks for your Help.
  10. #10
    May 2010
    Sebastian ,Fl
    2,464
    Enjoy the snow BRRRR
  1. 1992 bayliner capri classic with mercruiser alpha 1 gen 2 outdrive
    By flynavy21 in forum Mercruiser Sterndrive Forum
    Last Post: 06-23-2016, 05:30 AM
  2. 1992 Bayliner 2452 Engine Removal
    By Carl Jones in forum Mercruiser Sterndrive Forum
    Last Post: 01-17-2014, 02:33 PM
  3. 85 Bayliner Capri Engine Help
    By lil_sarge in forum Volvo Penta Gas Archive
    Last Post: 04-08-2007, 07:42 PM
  4. Did honda have a 23 liter engine for a 1986 bayliner capri
    By dcamille in forum Suzuki Outboard Archive
    Last Post: 03-25-2004, 06:45 PM
  5. Did honda have a 23 liter engine for a 1986 bayliner capri
    Last Post: 03-25-2004, 06:44 PM
