Results 1 to 6 of 6
    Default 1979 OMC 260/800 - No shift engine off.
    I have a 1980 Sea-Ray 225 with a OMC 260 model: 990262S which is a 1979 260 with the 800 Sterndrive left the model off since it appears to only be used at the factory.
    I just purchased this boat for REALLY cheap. The boat is really clean with low hours. It needs a stern drive water pump at minimum.
    It does not shift with the engine off. Not sure if this is normal or not because I do not want to start and run the engine.
    So with that background. I want to pull the stern drive. I want to replace the water pump. Of course drain and refresh all the oils looking for signs of leaks etc.
    What parts do I want to order beforehand? Water pump kit, any gasket kits for either the upper or lower? The exhaust bellows (if they are called that on this model) are rotted away so I will be pulling the exhaust risers off both manifolds and checking for clogs and replacing the exhaust bellows.
    Does the engine need to run to shift? Or do I more likely have some sort of other issue? Shift cable? Internal issues?
    Ideas? Suggestions? Gotchas?
    Sep 2010
    ontario
    14,481
    Default Re: 1979 OMC 260/800 - No shift engine off.
    If the shift cable going into the drive is broken the price of a new one will shock you.------Do a good investigation before spending any money on parts.
    Yea I have heard the price of a cable is EXTREMELY high. I am really surprised a company has not take that on. There is really nothing special about those cables.
    Dec 2006
    Chaumont Bay, N.y., USA
    5,373
    Quote Originally Posted by tekati View Post
    Ayuh,.... Not enough demand,... OMC is Gone,... Stringer drives were antique technology by '86,....
    In other words,... You bought a Dead Horse,...
    Sep 2010
    ontario
    14,481
    Have you looked at one of these cables ??
  6. #6
    First off no one has said the cable is bad yet. I was just looking for advice on my questions.
  1. 1979 70 hp evinrude shift shaft rod (engine to the lower unit) measurement.
    By primodude in forum Johnson Evinrude Outboard Forum
    Last Post: 09-15-2017, 08:38 PM
  2. 1979 I/O Shift Cable Goes Into Reverse But Not Forward
    By georgefielding in forum Mercury Mariner Outboard Forum
    Last Post: 04-05-2015, 07:07 AM
  3. 1979 80 hp mariner shift linkage
    By Mike Adams in forum Mercury Mariner Outboard Forum
    Last Post: 04-02-2014, 09:32 AM
  4. 1979 100hp will not shift
    By delanojjjj in forum Johnson Evinrude Outboard Forum
    Last Post: 05-25-2011, 06:50 PM
  5. 1979 johnson shift rod
    By bigheck in forum Johnson Evinrude Outboard Forum
    Last Post: 05-09-2010, 10:28 PM
