Hi guys I have a Bayliner with a mercruiser 3.0 eng it's been sitting for some time it's very hard to started . This is what I did to get it to start pull the plugs checked the compression all 4cyl 125 lb and up . The last cyl was blowing out fuel from the spark plug hole ok I put 3 spark plugs back in all but the #1 plug left that one out it started so I put in plug #1 wont start I did this a few times it started I even tried ether. I drained the water out it's getting cold at night I drained the manifold a some fuel come out with the water need help any ideas
Thank You
Thank You
