brbducksfan
We've been dealing with an overheat alarm with our boat for a while now. The boat runs, temp gets to 200, and the alarm goes off, putting boat into 'limp home' mode. We're stumped as to what's causing it. We have used a heat sensing gun to verify the temperature on the engine - of note, the ONLY spot where it's hot is by the top of the exhaust (near thermostat), everywhere else is cool. It does seem to 'cool off' pretty quickly after it overheats, but will then warm up to 200 again fairly quickly as well.
Here's what's been 'fixed' (replaced) so far:
impeller
water pump
thermostat
heat sensors were also checked (not replaced), as they are working
boat mechanic also checked for any leaks within the exhaust system and didn't find any
Based on isolated top of exhaust location of the 'overheat', we next did a pressure test on the 8 valves to see if a blown head gasket was a possibility - all 8 valves were within Volvo's "okay" range, but 1 valve was close to being outside of it. Based on this, we did a full head gasket replacement. After that was done and we tested it, I could tell we had been running on 7+ cylinders and the engine had more pop, but we still got the over heating alarm within 10 minutes of operation.
Any ideas for what to look at next would be greatly appreciated!
impeller
water pump
thermostat
