Results 1 to 8 of 8
  1. #1
    Join Date
    Jun 2017
    Location
    Ontario as well
    Posts
    100
    Default Fill plastic onboard tank or store it close to empty over the winter?
    Will be putting my 150 Prov V to sleep for the winter in about a month. Would I be better to store gas with stabilizer in it or try to empty the tank? Quite a bit easier to store full. It's a 35 gallon tank.
    Tia.
  2. #2
    Default Re: Fill plastic onboard tank or store it close to empty over the winter?
    Preferably....drain the tank, air and dry it out for winter storage. Siphon fuel into cans and mix in stabilizer. However, I must say you'd never catch me using 6 month old fuel, regardless of its stabilizer mixing. Using old fuel will cause far more dollars in repairs than the $100 you'd lose by disposing of the fuel.
  3. #3
    Join Date
    Jun 2017
    Location
    Ontario as well
    Posts
    100
    Just curious, do you not believe fuel stabilizers work? Thanks for your reply.
  4. #4
    Quote Originally Posted by Nucad View Post
    I do, and use a fuel stabilizer routinely. But as it relates to your situation, I wouldn't trust a stabilizer to maintain a tank of fuel over the course of 6 months. I have no scientific data which supports my opinion, it just seems realistic to me. Besides, it's not like you're trying to save 100+ gallons of fuel for 6 months. You're trying to save 100+ dollars. Seems logical to me to evacuate tank of fuel for the 6 months to completely offset any future fuel tank issues. Siphon the fuel into cans and add the stabilizer if you're really motivated to keep the 35g of fuel to use 6 months from now.
  5. #5
    Join Date
    Jun 2017
    Location
    Ontario as well
    Posts
    100
    I think what I will try to do is try to run the tanks near empty with stabilized fuel in them. That way when Spring comes I can dilute this with fresh gas. I guess my concern was with the potential for water getting in the tank through condensation when it is not stored full. Still hopefully have a month of boating ahead.
  6. #6
    Join Date
    Sep 2008
    Location
    Maryland - USA
    Posts
    7,374
    The potential for condensation is really a lot lower than the common dock myth will lead you to believe....read the instructions on the stabilizer - proper quantity should work for six months with no problem....that said, if you want to evacuate the tank, get burn it in the truck....
  7. #7
    Join Date
    Jun 2017
    Location
    Ontario as well
    Posts
    100
    I'd have to buy a pump to get the gas out of two 35 gallon tanks, but Since my car only holds ten gallons it would take some time to burn it up. Hopefully I get some good boating in between now and December.
  8. #8
    Join Date
    Oct 2007
    Location
    , ny, us
    Posts
    1,094
    Most boats have a water separator with a capacity of at least a pint or more. I don't believe most cars o​r trucks would be able to tolerate that much water without expensive damage occurring. The last time I was at the Toyota dealer, the labor rate was well over $125 per hour. At that rate, just dropping and cleaning the gas tank would be a $400 proposition. If other parts are damaged, the tab would be even higher and any warranty would not cover such damage. Unless you are absolutely sure the fuel is free of water or other contaminants, I would resist pouring it into any modern vehicle. One option might be to put it in the "free" section of Craigslist. Someone with carbureted equipment might find it useful for their snowblower, tractor or lawn equipment. For my purposes, trying to save a few bucks by storing and reusing the fuel doesn't seem to be worth the risk.
Similar Threads
  1. Replies: 1
    Last Post: 10-23-2017, 06:29 AM
  2. Leave the onboard Fuel Tank Empty or Full for the winter
    By thebubba in forum Mercury Mariner Outboard Forum
    Last Post: 11-18-2013, 09:48 AM
  3. proper way to store boat for winter
    By nperry_62 in forum Mercruiser Sterndrive Forum
    Last Post: 09-20-2010, 06:54 PM
  4. Onboard oil tank over filling
    By wildcatt in forum Yamaha Outboard Archive
    Last Post: 06-22-2009, 03:45 PM
  5. Winterize tank full close to empty or 12 to 34 full
    By slauder in forum Crusader Marine Archive
    Last Post: 12-01-2008, 09:51 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
