Results 1 to 10 of 10
    May 2014
    Reno
    258
    Default High speed jet removal
    I'm working on a 1967 6HP still,do I need a special tool to remove the high speed orfice in the carby? I don't want to booger it and I will purchase the tool if needed. Thank you-B
    84 Beachcraft 3.8 229cid 6681735 R drive6683545
    Apr 2010
    4,054
    Default Re: High speed jet removal
    Yes, go to any BRP dealer and he can get you one. Or wait for awhile and somebody on here will show you how to make one.
    Nov 2011
    1,775
    You maybe can make one if you are talented and have suitable tooling to do it. I made a bunch of them and I can tell you that it is surprisingly difficult to make a screwdriver. The secret to the jet screwdriver is the flat sides of the blade must be parallel. Off-the-shelf screwdrivers have tapered blades, which tend to spread the slot in the soft brass jet. That means the harder you try, the tighter it becomes. End of the story is you then wind up drilling it out.
    OK, OK, sure it might come out easy and none of that angst applies. How's your luck?
Name:	fixed jet screwdriver tip.jpg
    Nov 2011
    1,775
    Wow, that's surprising, I just checked the part number 0317002 here at marineengine and it comes up as obsolete. There has to be a new number for it. I'll check to see if I can find it.
    May 2014
    Reno
    258
    Any chance you still have one more than you need Frank?I thought obsolete meant that there is no longer any use for it. Anyway thanksfor the explanation, maybe I will try to customize a store bought one.
  6. #6
    Apr 2010
    4,054
    I used to find a screw driver with the right size straight shank, cut the end off and then grind the proper end on it. I've got about 4 or 5 of different length ones.
  7. #7
    Nov 2011
    1,775
    I bought a few of these a few years ago. Being hollow-ground, they are almost parallel, good enough. I'll look tomorrow to see if I have any left. I'll let you know by PM if I do.
Name:	Fixed jet screwdriver.jpg
  8. #8
    Apr 2010
    4,054
    That looks like one I made years ago except I had a nut welded on the end. Used it to get the lower jet out of a carb on a 1969 55hp.
  9. #9
    Nov 2011
    1,775
    The hollow ground bit that I pictured above is part number 5944A43 from mcmaster.com You might as well just order one direct from them. They don't cost much at all.
  10. #10
    May 2014
    Reno
    258
    Thanks so much guys,it ships today. With all of the knowledge you guys share it really makes this hobby fun-Blair
  1. Low speed high rpm
    By wegz15 in forum Johnson Evinrude Outboard Forum
    Last Post: 09-02-2014, 07:16 PM
  2. Removal/Cleaning of low speed orifice/jet
    By Catfish Hunter in forum Johnson Evinrude Outboard Forum
    Last Post: 05-01-2013, 11:46 PM
  3. How to set High speed and slow speed on carb: and what should the fiel ratio: be?
    By Wayne86 in forum Johnson Evinrude Outboard Forum
    Last Post: 04-01-2012, 11:36 AM
  4. High speed/low speed settings
    By KentLucas in forum Montgomery Wards Sea King
    Last Post: 06-23-2011, 11:58 PM
  5. 98 150 Engine running rough after high mid to high speed
    By ken88 in forum Johnson Evinrude Outboard Archive
    Last Post: 10-15-2007, 02:32 PM
