Hi,
This is my first post...I appreciate any help. I am looking at buying a used boat with twin 5.7 Crusaders. It is a 1996 fresh water boat with less than 300 hours. It looks like new. Upon my novice inspection last week, all looked good at first glance and the engines ran smoothly. However, on the starboard engine there were a dozen large drops of moisture accumulating on both oil caps. The dip stick oil looked clean, not milky at all. I cleaned the caps and we took the boat out for 30 minutes. The water was under the caps again. The port engine was fine. Both engines just had very faint steam coming from open caps.
I had a shop go inspect the engines. All compressions were between 155-164. He said all plugs looked normal. he poked around with a boroscope and all looked normal. The mechanic says he ran it in the slip for 30 minutes and there was no moisture on the caps after. I was not there to witness as I live far away. I asked the mechanic what he makes of all this and his best explanation was that they had a lot of humidity recently from some storms. I asked then why is port side nice and clean under the caps. He had no explanation.
FYI, after the mechanic left, I did have someone go open the caps the next day and there were numerous small drop of water under the cap.
My gut says there is something starting to go wrong with this engine. What are your thoughts? A few people I've talked to have said don't worry; and, others say worry. You advice is greatly appreciated.
Thanks, Jeff
Thanks, Jeff
