Results 1 to 6 of 6
  1. #1
    Default 1978 johnson 115 power trim problem
    the two small pistons work fine but the larger cylinder in the middle doesn't work. the motor sounds fine and it seems to e full of fluid. what can I check? thx, chris
  2. #2
    Join Date
    Apr 2010
    Posts
    4,251
    Default Re: 1978 johnson 115 power trim problem
    I gave you an answer on the other forum.
  3. #3
    also I can raise and lower the motor manually even with the side valve closed, seems like maybe the main cylinder is full of air maybe?
  4. #4
    anybody got any ideas?
  5. #5
    Join Date
    Feb 2001
    Location
    Central West Florida
    Posts
    14,508
    Quote Originally Posted by Boobie View Post
    Me too.
    We occasionally have questions. If you fail to answer, it may affect ours.
  6. #6
    well I guess I'm going to give up on this unit and buy one off ebay. does anyone know what years the power trim unit is interchangeable?
Similar Threads
  1. 1995 35 jet J50JEOD Johnson power tilt trim problem
    By alducks in forum Johnson Evinrude Outboard Forum
    Last Post: 09-25-2017, 06:45 AM
  2. 1978 Johnson power tilt & trim
    By Brad90 in forum Johnson Evinrude Outboard Forum
    Last Post: 11-17-2015, 09:16 PM
  3. 1978 Evinrude 85 Power Trim
    By LFF in forum Johnson Evinrude Outboard Forum
    Last Post: 08-08-2014, 12:16 PM
  4. 1978 55hp johnson power pack problem
    By 3mmm in forum Johnson Evinrude Outboard Archive
    Last Post: 06-03-2009, 09:11 PM
  5. 1978 Power trim and tilt
    By eggage1 in forum Johnson Evinrude Outboard Archive
    Last Post: 01-08-2007, 04:03 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
