Results 1 to 5 of 5
  1. #1
    Default 1984 Evinrude 8HP compression?
    What would normal compression be on a healthy motor?
  2. #2
    Join Date
    Sep 2010
    Location
    ontario
    Posts
    14,935
    Default Re: 1984 Evinrude 8HP compression?
    Why are you asking and what is the compression on yours ?
  3. #3
    I am asking because I would like to know, and mine is 135
  4. #4
    Join Date
    Sep 2010
    Location
    ontario
    Posts
    14,935
    That is excellent compression.----Motor should run very well.
  5. #5
    I hope so… So far I've only run it in a barrel
Similar Threads
  1. 1984 Johnson 90 HP Compression numbers
    By MitchB in forum Johnson Evinrude Outboard Forum
    Last Post: 08-25-2013, 09:27 AM
  2. 1984 30 hp johnson compression questions
    By supercb25 in forum Johnson Evinrude Outboard Forum
    Last Post: 11-03-2012, 10:35 PM
  3. 1984 evinrude 140 v4 does anyone know what my WOT RPM's should be?????????
    By tjrussell311 in forum Johnson Evinrude Outboard Forum
    Last Post: 02-10-2012, 03:42 PM
  4. 1984 Merc 200hp v6 compression test
    By ChocolateBayouGator in forum Mercury Mariner Outboard Forum
    Last Post: 08-06-2010, 05:52 PM
  5. 1984 454bs with low compression update
    By nightstalker in forum Crusader Marine Archive
    Last Post: 07-15-2009, 06:00 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
