Results 1 to 11 of 11
    Default 5.7 non-electric choke help !
    Hello, Newbie here. Bought a 1993 Celebrity with 5.7 motor. HARD to start. The choke will not close completely to start unless I put my finger on it, then starts instantly. All info I read refers to an electric choke. However this 2 barrel carb does not have an electric choke and I do not see how to adjust the choke to close .
    Attached are pictures of the carb. Motor runs like a champ once it starts !
    Jun 2008
    Island Heights, NJ,
    2,744
    Default Re: 5.7 non-electric choke help !
    Engine S/N please....
    Capt Bob
    1969 23ft ChrisCraft Lancer
    Merc 5.7L 260HP/ Volvo 280
    1972 22ft Bristol
    Honda 7.5HP 4 stroke Long shaft
    Sep 2008
    Maryland - USA
    7,095
    Picture(s)....I only saw one??
    If it has the 'stove' style coil on the intake, the adjustment is made by bending the link...like Bob asked, a serial number would help a bunch...
    Jun 2006
    Spotswood, NJ, USA
    4,094
    You do not have a 2barrel, its a Carter/Edlebrock 4 barrel http://www.boatfix.com/merc/Servmanl/16/16B5R2.PDF
    Thanks for the prompt reply. Where is the SN located ? Only numbers I see are the firing order and a some numbers on the riser castings ?
  6. #6
    Jun 2008
    Island Heights, NJ,
    2,744
    http://marinemechanic.com/merc/distr...lockcodes1.pdf
    page 1...
    Depending on era of engine, there is a paper decal with S/N on port elbow
    Capt Bob
    1972 22ft Bristol
  7. #7
    Jun 2006
    Spotswood, NJ, USA
    4,094
    But the engine serial number is on a tag just above the starter
  8. #8
    Jun 2006
    Spotswood, NJ, USA
    4,094
  9. #9
    Dec 2015
    maplevalley WA
    4,650
    Sounds like the bimetal spring is bad search 71464A01 it bolts onto the intake manifold and pulls the choke closed when cold.
    It takes a nickle to go first class!
    If it aint broke dont fix it!!
  10. #10
    Sep 2003
    New Tripoli, PA, USA!
    15,471
    J C Whitney used to sell an electronic choke conversion kit that worked really nice--used several of them.
    That said, unless your bimetallic strip (looks like a spring) isn't broken, you should be able to crank in enough closing force to solve your problem--unless something is binding and keeping the choke open. The choke pull off mechanism might be doing that, so take a careful look at it.
    Finally, as an olde mechanic, I've messed with carbs for over a half century and know how touchy the choke can be--especially since you only get one shot per day to get it right.
    Good luck!
    Jeff
  11. #11
    Thanks all for helping, I cannot get my head down close enough to the starter to see the SN tag. Anyway, with the schematic shown on the Weber attachment I understand how to bend the choke wire to shorten its stroke. I will proceed slowly and carefully. Thanks All.
  1. Electric Choke
    By earlbuddy in forum Johnson Evinrude Outboard Forum
    Last Post: 10-13-2014, 06:18 PM
  2. electric choke hook up
    By donsense in forum Chrysler Inboard and Sterndrive Forum
    Last Post: 09-15-2013, 06:35 AM
  3. electric choke
    By nicholas in forum Johnson Evinrude Outboard Forum
    Last Post: 02-13-2013, 04:46 PM
  4. ELECTRIC CHOKE
    By bobkoss in forum Mercruiser Sterndrive Archive
    Last Post: 05-19-2008, 07:23 PM
  5. 43l Electric Choke
    By Michael Murray in forum Mercruiser Sterndrive Archive
    Last Post: 03-27-2006, 04:30 PM
