Results 1 to 2 of 2
  1. #1
    Question 85, OMC 3.0 I/o engine lo up.Crank won't turn. What could it be?
    85, OMC 3.0 I/o engine locked up.Crank won't turn. What could it be? Could an overhead valve be locking it up or the transmission? Could the starter keep the crank from turning?
  2. #2
    Join Date
    Apr 2010
    Posts
    4,123
    Default Re: 85, OMC 3.0 I/o engine lo up.Crank won't turn. What could it be?
    Pull the outdrive. You'll get a better idea of where the problem is.
Similar Threads
  1. Engine won't crank
    By Mattlaf78 in forum Mercruiser Sterndrive Forum
    Last Post: 06-27-2017, 06:44 AM
  2. 5hp 4 stroke won't crank, won't turn a bit
    By srcook in forum Nissan Tohatsu Outboard Forum
    Last Post: 06-04-2015, 11:07 PM
  3. OMC 4.3L no crank/turn over
    By Neonzion in forum OMC Sterndrive and Inboard Forum
    Last Post: 08-20-2013, 09:28 AM
  4. Engine Temperature and Engine stall after turn
    By 3pointstar in forum Mercruiser Sterndrive Forum
    Last Post: 07-18-2010, 11:59 AM
  5. DF140 wonbt startwill crank but not turn over
    By jahman311 in forum Suzuki Outboard Archive
    Last Post: 09-18-2007, 02:42 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
