Results 1 to 2 of 2
  1. #1
    Default Throttle Linkage setting
    Found the screw loose holding the Roller Arm to the Roller Arm Hub on my 1998 150 Fast Strike, my question is where should I set the Roller Arm on the Hub. The hub has grooves as though it should be set in a certain location?
  2. #2
    Join Date
    Feb 2001
    Location
    Central West Florida
    Posts
    14,308
    Default Re: Throttle Linkage setting
    I retired from OMC in 1991 so I'm not familiar with your engine's design...BUT... this will get your post back at the top of the list..... However, If by "hub" and "grooves", you're speaking of the "Cam" and the "Scribe" marks on it... the throttle butterflies normally should just start to open when the first scribe mark aligns dead center with the throttle roller.
    We occasionally have questions. If you fail to answer, it may affect ours.
Similar Threads
  1. 110 Throttle Linkage
    By deepwoodsd in forum Mercury Mariner Outboard Forum
    Last Post: 05-30-2016, 05:41 AM
  2. 4.3l throttle linkage
    By leon phelps in forum Mercruiser Sterndrive Forum
    Last Post: 06-17-2015, 10:47 AM
  3. Throttle linkage adjustment
    By thebubba in forum Johnson Evinrude Outboard Forum
    Last Post: 04-26-2014, 12:49 AM
  4. Throttle and oil linkage
    By skeeter_mike in forum Yamaha Outboard Archive
    Last Post: 05-24-2009, 12:45 AM
  5. Powerhead throttle linkage
    By hitmiss in forum Johnson Evinrude Outboard Archive
    Last Post: 03-18-2006, 02:39 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
