MercuryMariner
MercuryMariner
MercuryMariner
MercurySierraCDI
Results 1 to 2 of 2
  1. #1
    Question Shift shaft lever 60 EFI Bigfoot 2006 goes too tight?
    My controller needs FORCE to go in- and out of gear. Kinda like the cables were twisted 4 times. I've isolateded the stiffness to be in the shift shaft lever, at the bottom front, under the ECM.
    Linkage disconnected, just the lever. With 2 kg of force I can push it between forward and neutral, I believe something gives in, if I try with more force to get in reverse. It gives a metallic hollow "BLOIK" when shifting between N and F.
    We HAVE been fiddling back and forth with the gears, with controller attached last week, in order to make linkage from controller fit. And.. I believe it has worsened since.
    Disassemble is taking the whole block off, in order to get to it. Is there a cowboytrick to try out, before taking the whole thing apart?
  2. #2
    Default Re: Shift shaft lever 60 EFI Bigfoot 2006 goes too tight?
    For some reason I can't change the topic - but this isn't the typical "shift shaft misalignment" - it does **** alright, it just needs FORCE. Force to the point where something is about to give in. I greased the hell out of it, through the grease-nipple at the "swingshaft" where it runs underneath. By the top lever and everywhere else along the way, I could find, with the side shields off.
    And it helped somewhat a little - BUT this has to be an issue seen before. Is the problem in the lower unit by the clutch?
Similar Threads
  1. 2006 6HP 4-Stroke shift lever replacement
    By NorthShore in forum Mercury Mariner Outboard Forum
    Last Post: 05-03-2017, 03:24 PM
  2. 2006 Mercury 6HP Shift Lever Replacement
    Last Post: 04-29-2017, 09:35 PM
  3. Mercury 2006 6HP 4-stroke shift lever replacement
    Last Post: 12-29-2016, 04:54 PM
  4. Mercury 2006 6HP 4-stroke shift lever replacement
    By NorthShore in forum Identifying Model / Year / Horsepower
    Last Post: 12-28-2016, 05:10 PM
  5. Connecting shift shaft to the shift lever in a 1994 60 hp evinrude
    By brucea952 in forum Johnson Evinrude Outboard Archive
    Last Post: 04-19-2004, 02:01 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
