Results 1 to 14 of 14
    Default Water Separator Thoughts???
    1989 70hp Johnson
    I had a problem with what was a good running motor. I was planning on removing my fuel tank to do some work in the bilge area. I ran the tank to about 1/4 full. I never got to remove it before running it again. The boat sat for about 3 weeks and during that time we had hurricane Irma and lots of damp humid weather during the 3 weeks it sat. I topped of the tank and took it out. Motor fired right up as normal. Idled fine and it ran for about 10 minutes at 3500 rpm with no issues. Then it bogged down and died. Re-started but continued to have running issues for hours. Some of the sounds I heard during the problem time were scary. Eventually I got it running good and got it home.
    Normally I always fill that fuel tank before putting it away. I'm thinking maybe I should add a water separator to prevent a similar issue. I know filling the tank should have prevented this, but I still thinking separator. I also know all about "leaving good alone".
    Thanks,
    John
    Nov 2011
    1,768
    Default Re: Water Separator Thoughts???
    So, what makes you think it was a water problem? (Not saying it wasn't--who knows).
    A water separator can remove a small amount of water, but it can be overwhelmed by a large amount of water, such as a contaminated fillup from the gas station's tanks.
    Why water problem? Not sure but I'm asking myself what was different after the motor was running fine last trip out. The difference that I came up with was not filling the fuel tank before putting it away. So I'm thinking fuel issue. I live in Florida where we get daily rain, high humidity and in this case a hurricane with 6+ inches of rain and high winds. Maybe water entry thru the vent in addition to condensation inside the tank.
    I'm going to change the in-line fuel filter and maybe add a water separator with visible bottom.
    Nov 2011
    1,768
    Yeah, I live in Florida too, and know all about that daily rain and humidity. But I've never experienced that amount of condensation in fuel tanks.
    Apr 2010
    4,050
    Take a fuel sample in a clear jar, leave it sit and check for water.
  6. #6
    Apr 2010
    4,050
    fdrgator, what part of FL do you live in ?? I spent time in the "eye" of Irma.
  7. #7
    Nov 2011
    1,768
    Sarasota, West Coast.
  8. #8
    Boat lived in Sarasota. I fled to Pensascola.
  9. #9
    Dec 2015
    maplevalley WA
    4,664
    Run the engine with a known clean portable tank and see if it cures the issue. Is that a permanent tank?
    It takes a nickle to go first class!
    If it aint broke dont fix it!!
  10. #10
    Yes permanent tank. I no longer own a portable tank.
  11. #11
    I added a water separator with clear bottom. Hopefully I don't regret it.
    I'm going to attribute my problem to hurricane Irma as I suspect the fueling station was under water and my purchase was made just after the storm.
    I'll see.
    Thanks,
    John
  12. #12
    Feb 2001
    Central West Florida
    14,316
    Quote Originally Posted by John Haggerty View Post
    I added a water separator with clear bottom. Hopefully I don't regret it. I'm going to attribute my problem to hurricane Irma as I suspect the fueling station was under water and my purchase was made just after the storm. I'll see. Thanks, John
    Smart move! Don't know why you think you might regret it.... Having a rig without a good one is ******** the way storms pop up in our neck of the woods (Tampa area).
    We occasionally have questions. If you fail to answer, it may affect ours.
  13. #13
    Sep 2010
    Jersey Shore
    4,826
    Are you burning E-10 in your engine?
    Chris
    Dockside Marine Services
    Jersey Shore.
    Mercruiser/Mercury Certified
    Let the insanity begin.
  14. #14
    Feb 2001
    14,316
    Quote Originally Posted by joereeves View Post
    I'm sure that starred out area was NOT a bad, cuss, or in general a fouled up word... can't imagine what I could have said to encounter that.
  1. Water separator
    By Gates in forum Mercury Mariner Outboard Forum
    Last Post: 08-18-2016, 04:04 AM
  2. water separator
    By cbelk in forum Mercury Mariner Outboard Forum
    Last Post: 06-29-2010, 07:59 PM
  3. Water Separator
    By jlblau in forum Honda Outboard Archive
    Last Post: 06-27-2008, 10:08 PM
  4. Fuel water separator
    By fjd in forum Volvo Penta Gas Archive
    Last Post: 08-18-2007, 11:30 PM
  5. Water separator Question
    By whfmznb in forum Outboard motors archive 2000-2004
    Last Post: 12-31-2002, 12:55 PM
