MercuryMariner
MercuryMariner
MercuryMariner
MercurySierraCDI
Results 1 to 9 of 9
  1. #1
    Default How's my idle? 2008 60HP 3 Cylinder
    Hey guys what do you think? I think it's a bit rough. Thanks in advance!
    https://youtu.be/2W_bopGkF5k
  2. #2
    Join Date
    Sep 2003
    Location
    New Tripoli, PA, USA!
    Posts
    15,557
    Default Re: How's my idle? 2008 60HP 3 Cylinder
    Missing like Nazi gold!
    Jeff
  3. #3
    Join Date
    May 2015
    Location
    Crosslake, Mn
    Posts
    51
    With the missing and the smoke, my guess is that you are running a little rich. Try a 1/8 CW turn on each of the carbs.
  4. #4
    Join Date
    Jun 2006
    Location
    Treasure Coast, FL
    Posts
    134
    Watching your video, your engine is doing the "EXACT" same thing at idle that mine is doing! I have adjusted the carbs to no end and they are "like new" inside and out. Please post your outcome if you figure it out. I plan on working on it some more today if the rain holds out.
    Does yours have a slight miss up to around 1900 RPM's as well? Or just a bumpy idle?
  5. #5
    Scott Bayes from Scott Bayes Marine adjusted mine. Adjusted timing and I think leaned it a bit. Here’s the end result. He’s worked on Mercs for ages / spe******t, and well known around here. I’m sure you could contact him on his website and ask him what he did exactly to my 60.
    Hers the after video. What a difference...
    https://youtu.be/G3jOyg4Uovk
  6. #6
    Join Date
    Sep 2003
    Location
    Posts
    15,557
    Quite a difference.
    Jeff
  7. #7
    Join Date
    Jun 2006
    Location
    Treasure Coast, FL
    Posts
    134
    That's a massive difference! That's how there supposed to sound at idle... I had a feeling it was something to do with timing as well. Looks like you're in a different country, so doubt they will be able to help unless they respond to emails? If I could talk to him for just a few minutes, I bet I could figure it out after that.
    Thanks for the reply and updated video!
  8. #8
    You could send him an email or give him a call. Just remember the time zone.
  9. #9
    Join Date
    Jun 2006
    Location
    Treasure Coast, FL
    Posts
    134
    Thank you. I spent some time under the cowling and on the water today and I finally figured it out. Lots of things out of whack. I got it running much better. Just a little fine tuning and it will be perfect. I'll update my thread with the details.
Similar Threads
  1. Help needed! Lower unit 2008 60hp 3 cylinder 2 stroke
    By FiveStar in forum Mercury Mariner Outboard Forum
    Last Post: 08-13-2016, 07:50 AM
  2. Water pump question 2008 60hp Merc 2 stroke - gear ratio
    Last Post: 07-19-2016, 06:41 PM
  3. Mariner 60hp efi four stroke 2008
    By danbr in forum Identifying Model / Year / Horsepower
    Last Post: 10-05-2014, 11:06 AM
  4. 2008 Yamaha 60hp no juice to starter or fuel pump
    By pescadito in forum Yamaha Outboard Forum
    Last Post: 07-05-2011, 12:42 AM
  5. Mariner 60hp 2 cylinder 2 stroke idle problems
    By steve webb in forum Mercury Mariner Outboard Archive
    Last Post: 07-28-2007, 09:16 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
