Results 1 to 2 of 2
  1. #1
    Default Power Tilt hydrolic line replacement
    I need to replace my power trim hoses on my Searay Sundancer 260. I have a leak in the hose inside the boat. The engine is a mercruiser 5.0 mpi
  2. #2
    Join Date
    Jun 2006
    Location
    Spotswood, NJ, USA
    Posts
    4,191
    Default Re: Power Tilt hydrolic line replacement
    remove the anode or zinc, remove the 2 nuts, pull block down, R/R line
Similar Threads
  1. Power trim tilt replacement motor
    By mike.l in forum Mercury Mariner Outboard Forum
    Last Post: 04-27-2017, 03:12 PM
  2. Hydrolic line ID and location.
    By Jerryjerry05 in forum Chrysler Force Outboard Forum
    Last Post: 06-15-2016, 06:53 AM
  3. 2006 8hp YAMAHA hydrolic trim and tilt ?
    By riverboater in forum Yamaha Outboard Forum
    Last Post: 11-22-2011, 08:24 AM
  4. {{WANTED, Tilt/Trim FASTRAK hydrolic manifold with rams}}
    By scumbuster in forum Johnson Evinrude Outboard Forum
    Last Post: 10-02-2011, 12:02 AM
  5. 97 power tilt trim motor replacement
    By pops86 in forum Johnson Evinrude Outboard Archive
    Last Post: 05-22-2008, 04:01 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
