Click for Honda Manuals, Parts and Model Guides!
Results 1 to 3 of 3
  1. #1
    Default Honda 20hp BAMJ-1023810 cannot Tilt on Manual
    Hello!
    Could some advise me on what the problem could be with my motors tilt release valve? I cannot tilt the motor when the valve screw is on 'manual' ...
    Motor is a Honda BF20 hp 4 stroke BAMJ-1023810
    Thank you.
  2. #2
    Join Date
    Mar 2009
    Location
    Cincinnati, OH USA
    Posts
    4,372
    Default Re: Honda 20hp BAMJ-1023810 cannot Tilt on Manual
    I am not sure what you mean by "on manual".r
    However, if you turn the tilt release valve counter clockwise a couple of turns, you should be able to raise your engine by physically picking up the lower unit until you get it to where you want it, then while you are holding it in place, have someone tighten the screw clockwise until it is tight. The motor should stay in place.
    Likewise, if the motor is already tilted up and you turn the screw counter clockwise, the engine should lower on its own weight. Tighten the screw clockwise, then you should be able to operate the tilt using the switch on the shifter.
    I hope that addressed your question.
    Mike
  3. #3
    Quote Originally Posted by hondadude View Post
    Mike
    Hi Mike,
    Thank you very much for your reply...
    I have turned the screw counter-clockwise to 'release' the motor but unfortunately it will not budge to full 'tilt up' position (currently down). I think it would best that I take it to our local mechanic to have a look at what the problem could be.
    Cheers,
    Brett.
Similar Threads
  1. manual primer 1985 20hp
    By newyota in forum Johnson Evinrude Outboard Forum
    Last Post: 03-21-2017, 12:51 AM
  2. 2016 20Hp Mercury 4- Stroke Tiller Manual Start
    By Bluewaterkeith in forum Mercury Mariner Outboard Forum
    Last Post: 01-08-2017, 10:53 AM
  3. Manual 2006 225 Honda Outboard Repair Manual
    By 208 Adventure in forum Honda Outboard Forum
    Last Post: 05-04-2016, 07:17 AM
  4. Johnson Owners Manual 1972 20hp
    By pedal in forum Johnson Evinrude Outboard Forum
    Last Post: 06-13-2010, 11:04 PM
  5. Mariner 20HP service manual
    By mariner20xd in forum Mercury Mariner Outboard Forum
    Last Post: 02-15-2010, 06:01 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
