Results 1 to 19 of 19
  1. #1
    Default 1972 evinrude flywheel doesnt spin all the way
    Hi everyone I am new too the forums so I hope this is in the right place. I have a 1972 evinrude 18hp outboard that suddenly stopped running today while out on the lake. Ive only taken this motor out 3 times so im not entirely familiar with it. today when i first brought it out it would not recoil the cord and I thought nothing of it. Then there was a rattling that I thought was coming from the motor cover but maybe not. I was at about 50% throttle when it stopped. I took out the sparkplugs and I can see the pistons move and I can feel compression. The flywheel will turn back and forth about 360 but wont go past a certain point when I turn it either direction.
    I have no idea what Is wrong I dont think it is seized but I am not sure any help is appreciated thanks!
  2. #2
    Join Date
    Sep 2010
    Location
    ontario
    Posts
    14,945
    Default Re: 1972 evinrude flywheel doesnt spin all the way
    Screws came loose under the flywheel ?-----Something wrong internally in the motor.----------I would start with removal of the flywheel.
  3. #3
    Join Date
    Nov 2011
    Posts
    1,806
    Agreed, remove the flywheel and check for something came loose in there. If that is ok, my guess is that the motor swallowed some small object which is now between one of the pistons and cylinder head. So pull the head if it looks good under the flywheel.
  4. #4
    Join Date
    Feb 2001
    Location
    Central West Florida
    Posts
    14,325
    In addition to the above on target suggestions, if the removal of the flywheel does not reveal the cause of the problem, remove the lower unit to determine where the problem is... the powerhead or the lower unit.
    We occasionally have questions. If you fail to answer, it may affect ours.
  5. #5
    Quote Originally Posted by racerone View Post
    Pulled flywheel and I don't see anything I'm going to pull lower unit now.
  6. #6
    Quote Originally Posted by pythontaco View Post
    Don't see anything wrong with lower unit. Tried pulling head and broke a head bolt so have to get that out. Will update after or if I'm able to get that bolt out.
  7. #7
    Join Date
    Feb 2001
    Location
    Posts
    14,325
    Use a hand held propane torch to heat the aluminum around tight fitting bolts/screws to help loosening them. Have the garden hose and a extinguisher handy though.
    I assume that your statement means that the power-head is the faulty component... bummer!
  8. #8
    Quote Originally Posted by joereeves View Post
    Unable to get the sheered bolt out. Also stripped head off another bolt. Going to let them soak and probably take it to machine shop tomorrow see if they can help take them out.
  9. #9
    Join Date
    Nov 2011
    Posts
    1,806
    Before you do, take the two intake bypass port covers off the side and peer in to see what you can see. If you see anything catastrophic, save your money.
  10. #10
    Quote Originally Posted by fdrgator View Post
    And of course I broke a bolt and stripped another one. And then broke an easy out in the stripped one. Looks like it has red locktite on the bolts.
  11. #11
    Join Date
    Nov 2011
    Posts
    1,806
    Who the heck would locktite those bolts in? Oh well. BTW, there ain't any such thing as an Easy Out. It isn't easy and they won't get them out.
  12. #12
    lol noted.
  13. #13
    Join Date
    Apr 2010
    Posts
    4,129
    And besides that, they have a habit of breaking off and then you are screwed when you try to drill them out. VOE.
  14. #14
    Went to machine shop and they were nice enough to help get the stubborn bolt on the intake cover. Opened up and still don't see anything. Ive got to find a friend with a cut off wheel to help get the last head bolt out and maybe then I can finally see if there is any damage.
  15. #15
    Join Date
    Apr 2010
    Posts
    4,129
    Ever have any luck ??
  16. #16
    Quote Originally Posted by Boobie View Post
    Been busy with life. Going to pick up a torch in the next couple days and try to get that head stud off. I will definitely update once I get the head off.
  17. #17
    Okay, I had same problems on a 25 and I learned a trick that has worked ever since.
    Get a boxend wrench that fits the bolt and leaves just a little of the head sticking out above the wrench. Now put some good pressure on the wrench and tap on the bolt head pretty sharply.That has brought them out every time for me.
  18. #18
    Join Date
    Dec 2015
    Location
    maplevalley WA
    Posts
    4,743
    One of those 1/4" drive cordless impact drivers work good also. You can also bust lug nuts with the right size socket adaptor.
    It takes a nickle to go first class!
    If it aint broke dont fix it!!
  19. #19
    Bolt is stuck in and even heat hasn't helped get it out. At this point I'm spending more money on tools just to get the damn thing apart. I have no access to a die grinder or welder and I'm running out of patience. The last bolt is stripped and I'm no where closer to figuring out what is wrong. I spent 300 on this motor lasted me about 2 short trips. Considering just cutting my losses. Opinions?
    Buying air compressor and other heavy duty tools is not an option. As I live in an apartment rn. Also I'd like to say I appreciate everyone's help.
Similar Threads
  1. Evinrude 150 flywheel key
    By Dfowler in forum Johnson Evinrude Outboard Forum
    Last Post: 04-14-2013, 10:24 PM
  2. 1978 Evinrude 75 HP; misfires, battery doesnt charge
    By JeanArr in forum Johnson Evinrude Outboard Forum
    Last Post: 06-22-2012, 03:48 AM
  3. 1972 18hp fastwin prop spin out??
    By deepwoods in forum Johnson Evinrude Outboard Forum
    Last Post: 06-08-2010, 11:05 PM
  4. 19921993 Nissian 35 Prop doesnt spin
    By wingnut in forum Nissan Tohatsu Outboard Forum
    Last Post: 05-25-2009, 11:24 AM
  5. Torque Spec for 1972 Evinrude 18 hp flywheel nut
    By j_scott in forum Johnson Evinrude Outboard Archive
    Last Post: 10-26-2008, 04:07 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
