MercuryMariner
MercuryMariner
MercuryMariner
MercurySierraCDI
Results 1 to 4 of 4
  1. #1
    Default mercury 50hp 4 cylinder
    hi i have just got a 50 hp mercury . it has stood for 2 years . when started it run fine but no water coming from the tell tail . how hard is it to part the leg from the power head thanks
  2. #2
    Join Date
    Sep 2010
    Location
    ontario
    Posts
    14,945
    Default Re: mercury 50hp 4 cylinder
    Just a few nuts to take off with shift lever in forward.-----There may be a hidden nut under the trim tab.
  3. #3
    thank you will have a look
  4. #4
    Join Date
    Sep 2003
    Location
    New Tripoli, PA, USA!
    Posts
    15,556
    There's a 4th nut hiding under the trim tab, which is removed from above.
    Jeff
Similar Threads
  1. 1983 Mercury 50HP four cylinder not firing any
    By bdukes in forum Mercury Mariner Outboard Forum
    Last Post: 04-04-2016, 11:54 PM
  2. 1983 Mercury 50hp 4 cylinder
    By Carvey in forum Propeller Selection and Replacement
    Last Post: 03-31-2016, 02:09 AM
  3. 1986 Mercury 3 Cylinder 50hp Not Starting
    By imhuntsm in forum Mercury Mariner Outboard Forum
    Last Post: 07-20-2015, 11:10 PM
  4. 2008 50hp Mercury 3 cyl 2 stroke with bad compression on one cylinder
    By got2haveit in forum Mercury Mariner Outboard Forum
    Last Post: 08-26-2013, 11:11 PM
  5. MERCURY 50HP IMPELLER 3 CYLINDER 2 STROKE
    By davidxxx in forum Mercury Mariner Outboard Archive
    Last Post: 07-18-2009, 11:38 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
