MercuryMariner
MercuryMariner
MercuryMariner
MercurySierraCDI
Results 1 to 6 of 6
  1. #1
    Default 7.5 exhaust leak
    I have installed new baflfle plate and both gaskets. Water holds fine but exhaust is leaking a lot from the exhaust manifold. Is there a permetx gasket caulk that will seal the leak?
  2. #2
    Join Date
    Sep 2003
    Location
    New Tripoli, PA, USA!
    Posts
    15,471
    Default Re: 7.5 exhaust leak
    Did you use bolts that are too long (or the tapped holes were not cleaned out)? No way should it leak like that.
    Jeff
  3. #3
    Quote Originally Posted by fastjeff View Post
    Jeff
    Good tip, I checked the treaded holes and they are deep enough. I may use a high tem permitex.
  4. #4
    Join Date
    Dec 2015
    Location
    maplevalley WA
    Posts
    4,650
    Permatex aviation just brush a light coat on both sides of the gaskets and snug the bolts down good. You should see a light bead squish out all the edges of the gasket.
    It takes a nickle to go first class!
    If it aint broke dont fix it!!
  5. #5
    Join Date
    Dec 2015
    Location
    maplevalley WA
    Posts
    4,650
    Do not use silicone
  6. #6
    Join Date
    Sep 2003
    Location
    Posts
    15,471
    You should not need ANY sealant to get it to work properly. I suspect something is warped.
    Jeff
Similar Threads
  1. Replies: 6
    Last Post: 10-02-2017, 10:03 PM
  2. Is this an exhaust leak?
    By ship wreck in forum Johnson Evinrude Outboard Forum
    Last Post: 09-08-2013, 10:11 PM
  3. 40 hp exhaust leak
    By frozenfish in forum Yamaha Outboard Forum
    Last Post: 07-20-2010, 03:04 PM
  4. Exhaust Leak
    By jimw in forum Crusader Marine Archive
    Last Post: 07-23-2009, 06:37 AM
  5. Exhaust Leak
    By mschwenz in forum Mercruiser Sterndrive Archive
    Last Post: 07-15-2009, 09:43 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
