Results 1 to 3 of 3
  1. #1
    Howie Hogle's Avatar
    Howie Hogle Guest
    Default " I have a 1984 Evinrude 90hp
    " I have a 1984 Evinrude 90hp o/b, this motor seems to only have a rectifier with no regulator for charging volts, my volts guage will climb to near 18 volts while running. Any suggestions would be appreciated. "
  2. #2
    Tony Delio's Avatar
    Tony Delio Guest
    Default " Howie, Your engine should
    " Howie,
    Your engine should have a rectifier and a regulator. It sounds like you need to replace the regulator.
    Tony "
  3. #3
    Join Date
    Feb 2001
    Location
    Central West Florida
    Posts
    14,309
    Default "If your engine is indeed a 19
    "If your engine is indeed a 1984 Evinrude it would have one of the model numbers as follows: E or J 90MLCRD, 90LCCRD, or 90TXCRD.
    Now, if you have Power/Tilt/Trim (PTT), you should have a 10 amp stator under your flywheel (OMC part # 582867--># 583672), in which case your engine should have a water cooled voltage regulator/rectifier assy located on top of the block, between the cyl heads, near the rear of the engine (OMC part # 582094--># 395391--># 395204)
    If you do not have PTT, you should have a 6 amp stator under that flywheel (OMC part # 582016--># 583671), in which case a voltage regulator would not be used, but would rather use a small rectifier (OMC part # 582339--># 583408) located on the starboard (right) side of your engine near the terminal strip.
    You can determine which stator your engine has by removing the flywheel. The part number will be imprinted on top of the stator, usually at the top front area. Be sure to torque that flywheel to 105 foot pounds when you reinstall it.
    If you have the 6 amp stator combined with the small rectifier, do not be concerned with the voltage reading as the amperes are low. You can get a volt meter to read extremely high with a bunch of AAA flashlight batteries, but the amperes are not there. In short, that creates no problem.
    However, if that stator is a 10 amp, and you have the small rectifier instead of the voltage regulator assy, that may create a problem somewhere in the future but it's not a certainty as I've seen many a engine with this type cross mix that have been running for years with no associated charging problems..... but it is a gamble.
    Pertaining to what battery life you can expect. I have no idea and wish I did as I'd be able to predict when my car battery would fail....... again <sigh/grin>.
    Joe[img][/img]"
    We occasionally have questions. If you fail to answer, it may affect ours.
Similar Threads
  1. 1959 EVINRUDE 35HP Charging system
    By gearhead93 in forum Johnson Evinrude Outboard Archive
    Last Post: 05-12-2006, 11:52 PM
  2. 95 Evinrude 88 SPL charging system
    By hunkywhaler in forum Johnson Evinrude Outboard Archive
    Last Post: 05-06-2006, 04:12 AM
  3. 89 evinrude 120 charging system
    By randy in forum Johnson Evinrude Outboard Archive
    Last Post: 05-11-2004, 06:31 PM
  4. Charging System Not Charging
    By donnella in forum Archive 2002-2006
    Last Post: 08-17-2003, 10:02 PM
  5. 65b evinrude charging system
    By mrcipp in forum Johnson Evinrude Outboard Archive
    Last Post: 06-24-2003, 06:26 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
