Results 1 to 26 of 26
  1. #1
    Join Date
    Sep 2017
    Location
    WI
    Posts
    11
    Question Need engine coupler for Ford 5.8L to King Cobra
    I have a 93 Four Winns with a 5.8L, 360 HP connected to a King Cobra I/O drive. The splined sleeve spun leaving no splines. I need an OMC engine coupler P/N 987528 or suitable substitute. I have been scouring every on-line marine salvage site for this part. Anyone have any ideas? The boat is in excellent shape, the engine runs strong and the lower unit is excellent. The coupler, however is required! Thanks...
  2. #2
    Join Date
    Dec 2015
    Location
    maplevalley WA
    Posts
    3,860
    Default Re: Need engine coupler for Ford 5.8L to King Cobra
    Give seaway a call 425-412-4006 weekdays only you got an hour or wait till monday.
    It takes a nickle to go first class!
    If it aint broke dont fix it!!
  3. #3
    Join Date
    Sep 2017
    Location
    WI
    Posts
    11
    [QUOTE=kimcrwbr1;589630]Give seaway a call 425-412-4006 weekdays only you got an hour or wait till monday.
    I e-mailed their site and received a response that they do not have the part. Thanks for the recommendation. A salvage yard in NH directed me to them.
  4. #4
    Join Date
    Dec 2015
    Location
    maplevalley WA
    Posts
    3,860
    Will a VP coupler work? # 3853862 or 3850520 Ricardo may know or have one?
  5. #5
    Join Date
    Dec 2015
    Location
    maplevalley WA
    Posts
    3,860
    From my research the coupler #3853862 or sierra 18-21753 is the ticket from a 1994 OMC 5.8l
  6. #6
    Join Date
    Dec 2015
    Location
    maplevalley WA
    Posts
    3,860
    Are you going to replace the gimbal bearing and U-joints?
  7. #7
    Join Date
    Sep 2017
    Location
    WI
    Posts
    11
    I will try the coupler you listed. The U-joints and gimbal bearing were replaced about 2-3 years ago when I could feel, at low speed, a vibration that was not normal. At that time the coupler was not examined.
    Where did you research that this coupler will possibly work? I have been working on this since early August and no one has suggested that this may work. Just curious.
    Thank you.
  8. #8
    Join Date
    Dec 2015
    Location
    maplevalley WA
    Posts
    3,860
    I would wait for word from Ricardo. I cross referenced the yoke and gimbal bearing for the 1994 supersede I could not confirm the bolt pattern for the flywheel bolts tho. Yea I am surprised OMC does not give you numbers the original number was only for two years for the king cobra drives 93-94. I just checked the numbers I gave you are the same for the 1991 5.8.
  9. #9
    Join Date
    Sep 2017
    Location
    WI
    Posts
    11
    [QUOTE=kimcrwbr1;589659]I would wait for word from Ricardo. I cross referenced the yoke and gimbal bearing for the 1994 supersede I could not confirm the bolt pattern for the flywheel bolts tho. Yea I am surprised OMC does not give you numbers the original number was only for two years for the king cobra drives 93-94. I just checked the numbers I gave you are the same for the 1991 5.8.
    I assume Ricardo is another contributor to this site and will eventually read my question.
  10. #10
    Join Date
    Sep 2017
    Location
    WI
    Posts
    11
    I had ordered the OMC 3853862/Sierra 18-21753 prior to starting this string. There is a 5/8" difference in height where the flange for connecting to the flywheel is. Also the"sleeve" that slides through the bell housing is shorter. The technician at my marina is concerned that the additional height will not allow the lower unit to fit tight against the transom.
    Anyone have any other possible substitutions for an OMC 987528 coupler?
    Thanks...
    Attached Thumbnails Attached Thumbnails Click image for larger version.
  11. #11
    Join Date
    Dec 2015
    Location
    maplevalley WA
    Posts
    3,860
    There are two different yokes the only thing I can think of is you have the long yoke I will find the part number for the short yoke.
  12. #12
    Join Date
    Dec 2015
    Location
    maplevalley WA
    Posts
    3,860
    Do you have the drive off of the transom plate? Put the couplers on the yoke and measure from the flange where it bolts to the flywheel to the flat spot on the yoke.
  13. #13
    Join Date
    Sep 2017
    Location
    WI
    Posts
    11
    Unfortunately at noon I dropped the replacement coupler in the mail to return. I know the drive shaft on the lower unit from the end of the shaft to the base of the yoke on the shaft is 9". If you measure from the end of the shaft to the C/L of the yoke it is 12 inches. I believe, not sure, that I have the shorter shaft of the two.
  14. #14
    Join Date
    Dec 2015
    Location
    maplevalley WA
    Posts
    3,860
    I wish someone who know would chime have you measured how far in the coupler the splines are stripped? Are there any good splines left in the coupler?
  15. #15
    Join Date
    Sep 2017
    Location
    WI
    Posts
    11
    The coupler spines are completely gone. There is not a spine left. I was very surprised when I saw this as it was a complete catastrophic failure. I would have expected the splined sleeve to spin in the rubber before sheering all of the splines away. The splines on the drive shaft are perfect. I assume that there is a difference in material composition. When the lower unit was pulled all of the shavings, full length of the spline dropped out.
  16. #16
    Join Date
    Nov 2011
    Location
    tennessee
    Posts
    2,716
    Here is a idea....Just use the Serria coupler and a early style Mercruiser stub shaft as its shorter
    Pappys Sales and Service
    Owner and Factory Certified Technician
    Former racer KDBA (Kentucky Drag Boat Association)
  17. #17
    Join Date
    Sep 2017
    Location
    WI
    Posts
    11
    Faztbullet, thank you for the suggestion. The concern remains that the new coupler's flange that attaches to the flywheel is 5/8" taller than the original. Thus it will either not allow the engine to fit back in or will hit/rub the transom. It does not appear that the shaft it the concern as it is the shorter shaft available.
  18. #18
    Join Date
    Jun 2006
    Location
    Spotswood, NJ, USA
    Posts
    3,902
    Considering the shaft assembly is a Mercruiser type a short shaft is available. The same for the U joints and gimbal bearing. So considering a Mercruiser coupler would work all you need to do is have a flywheel accept the bolt pattern for a Bravo coupler to handel the horsepower
  19. #19
    Join Date
    Sep 2017
    Location
    WI
    Posts
    11
    Doctur, Faztbullet and kimbrwct1, I did a lot of research on which Merc coupler(s) would be the correct substitute based on your advice. The Sierra P/N # appears to be 18-21752-1. It is a replacement for OMC #'s 986120, 984290 and 3853917. How do I determine which is the correct shaft to match this coupler? I assume that all shafts do not have the same spline design so I will not be able to use the current shaft.
  20. #20
    Join Date
    Dec 2006
    Location
    Chaumont Bay, N.y., USA
    Posts
    5,273
    Ayuh,.... I'm guessin' yer assumin' wrong,....
    Just as gimbel bearin's, 'n alignment tools are all the same, every drive spline I've run across are also the same,....
  21. #21
    Join Date
    Sep 2017
    Location
    WI
    Posts
    11
    Bondo, I was not aware of that. Thank you.
  22. #22
    Join Date
    Sep 2017
    Location
    WI
    Posts
    11
    I have continued to search for the correct coupler. During my search I found another string where the engine and sterndrive are the same P/N's as mine. The difference is that it is in a 92 Liberator not a 93 Horizon. I am now wondering if that it the cause for having such difficulty in locating the correct coupler. I was wondering why I could not find my engine in 93 listings. This answers that question.
    Does this help in finding the right coupler?
    Engine: P/N 584DPEAMK S/N 1242537
    Sterndrive: P/N 987526 S/N T0756893
  23. #23
    Join Date
    Jun 2006
    Location
    Spotswood, NJ, USA
    Posts
    3,902
    Your engine uses a flywheel just like a Merc .Your coupler bolts to the crankshaft where Merc bolt the coupler to the flywheel .The Bravo coupler will take the horespower of your motor . If your flywheel can accept a autoclutch and pressure plate it will also accept a Bravo coupler
  24. #24
    Join Date
    Dec 2006
    Location
    Posts
    5,273
    Ayuh,..... IF, it'll fit inside the flywheel cover,....
  25. #25
    Join Date
    Jun 2006
    Location
    Spotswood, NJ, USA
    Posts
    3,902
    Well ,could always drop a merc 6.2 stroker package in and use the merc transom
  26. #26
    Join Date
    Dec 2006
    Location
    Posts
    5,273
    Quote Originally Posted by Bt Doctur View Post
    Ayuh,.... At that point, I'd scrap the OMC altogether, 'n go Merc, or Volvo,....
Similar Threads
  1. 1987 Ford 23 OMC engine coupler
    By afidowicz in forum OMC Sterndrive and Inboard Forum
    Last Post: 08-18-2009, 04:18 PM
  2. 57 OMC Cobra Engine coupler center worn out when out drive up
    By rcdarkknight in forum OMC Sterndrive and Inboard Archive
    Last Post: 07-15-2007, 02:58 PM
  3. Water in King Cobra engine oil
    By ivydawg in forum OMC Sterndrive and Inboard Archive
    Last Post: 05-17-2006, 12:55 AM
  4. OMC King Cobra dog clutch for a 460 Ford
    By Shari in forum OMC Sterndrive and Inboard Archive
    Last Post: 04-12-2006, 09:44 PM
  5. 23 Ford OMC Cobra Coupler
    By Bob Hill in forum OMC Sterndrive and Inboard Archive
    Last Post: 12-31-1969, 08:00 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
