Results 1 to 5 of 5
  1. #1
    Join Date
    Feb 2007
    Location
    Posts
    232
    Default 2008 Mercruiser 5.7 TBI rpm loss after 5 min. at cruise spd.
    Hi Gang
    I have a twin engine inboard Pursuit I am working on. The motors are 2008 5.7 fwc TBI with dry joint exhausts and a serpentine belt setup. These are Mercruiser replacement motors. They idle and run smoothly.
    After 5-7 minutes of running both motors at 3200 rpms, the port engine hiccups, bogs and drops down to 2500 rpm. If I return the throttle lever to neutral and accelerate up to 3200 once again the problem re occurs after 5-7 minutes of operation like clockwork.
    I can cruise all day at 2800 rpm on both motors and all is fine.
    The fuel vents are clear and the fuel filters are new. Any ideas?
    Thanks in advance
    Jon Allen
  2. #2
    Join Date
    Sep 2003
    Location
    New Tripoli, PA, USA!
    Posts
    15,558
    Default Re: 2008 Mercruiser 5.7 TBI rpm loss after 5 min. at cruise spd.
    Clogged anti-siphon valve?
    Jeff
  3. #3
    Join Date
    Feb 2007
    Location
    Posts
    232
    Hi Jeff
    That's what I was thinking as well.
    However I don't see how it could run for 5-7 minutes at cruise speed if that were the case. I will probably be attatching a fuel pressure/vacuum guage to it to verify.
    Jon
  4. #4
    Join Date
    Sep 2008
    Location
    Maryland - USA
    Posts
    7,184
    could be picking up crud on the dip tube screens as well.....either way, the pressure/vacuum gauges would be prudent....and definitive....
  5. #5
    Join Date
    Feb 2007
    Location
    Posts
    232
    Hi Jeff and Mark
    Thank you both for your help. I always like to consult the real professionals.
    I will run a fuel pressure check on both the LP and HP pumps as well as measure vacuum just before the tank on the suction side.
    Thanks Again
    Jon
Similar Threads
  1. 2008 Mercury Optimax 115 hp, loss of power
    By oceanhunter in forum Mercury Mariner Outboard Forum
    Last Post: 09-06-2016, 10:50 PM
  2. 2008 5.0 MPI Loss of power and ticking noise on port side exhaust.
    By Joe Lake Spivey in forum Mercruiser Sterndrive Forum
    Last Post: 08-05-2016, 07:35 PM
  3. 2008 V-Mercruiser
    By Endicott in forum Mercruiser Sterndrive Forum
    Last Post: 07-18-2016, 12:39 PM
  4. 2008 3,o mercruiser
    By gordr in forum Mercruiser Sterndrive Forum
    Last Post: 03-30-2016, 09:53 PM
  5. 2008 Merc 60/40 Jet 4 stroke EFI loss of power
    By dsluck in forum Mercury Mariner Outboard Forum
    Last Post: 07-06-2012, 09:35 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
