Click for Volvo Penta parts and manuals!
Results 1 to 2 of 2
  1. #1
    Default what happens if you install the wrong flywheel? internal /external balance engine?
    i am trying to locate the correct flywheel for my boat but i dont know if my engine is externally or internally balanced
    97 4.3 gm engine, 1 piece rear main seal in volvo penta set up
  2. #2
    Join Date
    Mar 2009
    Location
    Portland, Oregon,
    Posts
    9,813
    Default Re: what happens if you install the wrong flywheel? internal /external balance engine?
    While I would not normally suggest Automotive people for Marine topics...... this is one question best suited for a very well experienced Automotive engine builder and/or Machinist expert!
    In answer to your question...... if the engine in question requires a certain flywheel in order to externally balance the rotating assembly, and if that flywheel is not used, you will realize a vibration.
    Rick ... aka Ricardo..... AQ series Volvo Penta repair
    Portland, Oregon
    28' SDN F/B w/ twin Volvo Penta 5.7L DP's
    Please... no PMs! Post your questions on the forum.
Similar Threads
  1. M5B Internal to External Tank Conversion
    By s2sailorlis in forum Nissan Tohatsu Outboard Forum
    Last Post: 12-21-2016, 07:30 AM
  2. Replies: 0
    Last Post: 11-06-2013, 03:25 PM
  3. AQ120b Alternator: Internal or external regulator?
    By pugetsounder in forum Volvo Penta Gas Engine Forum
    Last Post: 11-19-2011, 08:37 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
