Results 1 to 6 of 6
  1. #1
    Question Please help 1971 Johnson 60 hp bottom cylinder misfire
    Johnson 60ES71C
    The bottom cylinder on my motor intermittently drops out. I've rebuilt the carbs,( even I swapped top carb with bottom one, still same!) rebuilt the fuel pump, replaced all fuel lines, and replaced the plugs and wires. I checked the stator and pickup as per instructions on the CDI website. I have wiggled all wires and inspected all connections, cleaned and secured all ground wires. I'm performing all these tests on the muffs in my driveway. So what do you guys think? Power Pack? Coil? or both?? Thanks, Riddick
  2. #2
    Join Date
    Sep 2010
    Location
    ontario
    Posts
    15,263
    Default Re: Please help 1971 Johnson 60 hp bottom cylinder misfire
    Did you clean and set the points ?----Clean the distributor cap and rotor ?----------Replaced the rubber boot where plug wire screws into the cap ?
  3. #3
    Join Date
    Nov 2011
    Posts
    1,933
    The amplifier works the same on the bottom cylinder as the other two. Likewise, the coil. Do what racerone said.
  4. #4
    I did clean everything and put a new rubber boots too, but still the same.
  5. #5
    Join Date
    Nov 2011
    Posts
    1,933
    OK, back to basics. You checked the compression? Not getting water intrusion into the cylinder? Put a spark gap tester on #3 and observed the spark (or lack thereof) while it is acting up? Set the points at .009"? Is it cutting out at a particular RPM? If only at idle, are all 3 carbs closing completely? Slow speed needle adjustment make any difference?
  6. #6
    Join Date
    Apr 2010
    Posts
    4,260
    Check the distributor cap for any carbon tracks.
Similar Threads
  1. 83 johnson v4 have water in bottom right cylinder
    By james12 in forum Johnson Evinrude Outboard Forum
    Last Post: 09-01-2015, 08:13 AM
  2. 1988 Yamaha 6 Cylinder misfire
    By skip40 in forum Yamaha Outboard Forum
    Last Post: 05-23-2012, 07:55 PM
  3. Misfire on bottom cylinder at idle04 johnson 40 hp j40plsrs
    By timswenson in forum Johnson Evinrude Outboard Archive
    Last Post: 09-14-2008, 12:06 PM
  4. Johnson 1971 60HP 3 cylinder ignition
    By limeyboy in forum Johnson Evinrude Outboard Archive
    Last Post: 07-14-2008, 12:56 PM
  5. 1981 35hp Johnson NO FIRE ON BOTTOM CYLINDER
    By Darrell Mac Nall in forum Johnson Evinrude Outboard Archive
    Last Post: 07-22-2003, 09:27 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
