MercuryMariner
MercuryMariner
MercuryMariner
MercurySierraCDI
Results 1 to 3 of 3
  1. #1
    Default Rev limiter or power pack
    I have a 2002 50 hp 2 stroke with no spark. I have eliminated the kill circuit. I have replaced the rectifier, it had melted wires. I replaced the trigger, bad ohms readings., I replaced the stator, I had a new one and I had the flywheel off, however, the only things I did not replace is the rev limiter or any coils. my question is the rev limiter doubling as the power pack/ cdm? Really stuck on this one.
    Fred
  2. #2
    Join Date
    Nov 2011
    Location
    tennessee
    Posts
    2,901
    Default Re: Rev limiter or power pack
    Nope......is stator correct one? Disconnect limiter as could be driving stator to ground.
    Pappys Sales and Service
    Owner and Factory Certified Technician
    Former racer KDBA (Kentucky Drag Boat Association)
  3. #3
    Join Date
    Dec 2015
    Location
    maplevalley WA
    Posts
    4,748
    Yea take the rev limiter out of the loop. That is the three cylinder correct? It has three CDMs basically the coils are the power packs. If you get spark by disconnecting the rev limiter. I could be a faulty coil go to boat info library and find your motor it will tell you how to diagnose ignition issues. One bad coil can keep the others from firing you may need a special harness to isolate the faulty coil.
    It takes a nickle to go first class!
    If it aint broke dont fix it!!
Similar Threads
  1. Power Pack
    By boatbickle in forum Johnson Evinrude Outboard Forum
    Last Post: 11-24-2010, 09:04 PM
  2. Replies: 2
    Last Post: 06-10-2010, 01:22 PM
  3. Replaced power pack now no power under load
    By marineman43 in forum Johnson Evinrude Outboard Archive
    Last Post: 09-08-2009, 11:17 AM
  4. Power pack
    By fishingman in forum Johnson Evinrude Outboard Archive
    Last Post: 02-16-2008, 01:26 PM
  5. Could this be a bad power pack
    By beachfloater in forum Mercruiser Sterndrive Archive
    Last Post: 04-23-2006, 10:31 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
