Results 1 to 4 of 4
  1. #1
    Default 1988 Johnson 90hp Water in cylinder
    I purchased a 1988 Johnson 90hp VRO this spring. Installed it on my 1960 17'6" EM white. The first time I used it I found it was lacking power. Not a lot but 70hp could walk away from me. Changed plugs when installed. After a few trips I decided to see what the spark plugs looked like. Pulled all the plugs and noticed #4 cylinder looked milky but still had coloring like it was firing. So I pulled head and replaced gaskets. Still getting water droplets in cylinder. Cylinder compression test was 125 in all cylinders befor and after. Any suggestions?
  2. #2
    Join Date
    Nov 2011
    Location
    tennessee
    Posts
    2,901
    Default Re: 1988 Johnson 90hp Water in cylinder
    Lower crank seals
    Pappys Sales and Service
    Owner and Factory Certified Technician
    Former racer KDBA (Kentucky Drag Boat Association)
  3. #3
    Just replaced exhaust cover gaskets. Still have water droplets. How dose water work it's way up to the crank seals? I'm running it with muffs and a storage bucket filled with water to keep the noise down.
  4. #4
    I will pull the power head and replaced the seal. Any other problem areas I should take inspect? It was run in salt water a lot. I cleaned up all the ports in the heads.
Similar Threads
  1. 1985 90hp merc 6 cylinder blue smoke and water from engine cover
    By jsd3024 in forum Mercury Mariner Outboard Forum
    Last Post: 04-05-2016, 06:28 PM
  2. Johnson 1990 90HP Water in cylinder
    By rude70 in forum Johnson Evinrude Outboard Forum
    Last Post: 04-17-2013, 10:22 AM
  3. Water in Cylinder 90Hp Johnson V4 CE model
    By Kingy68 in forum Johnson Evinrude Outboard Forum
    Last Post: 02-03-2011, 07:45 AM
  4. 90hp Mariner 1988 3 cylinder intermittant spark problems
    By zeek in forum Mercury Mariner Outboard Archive
    Last Post: 01-03-2007, 01:07 AM
  5. 1988 Johnson 90hp
    By alarider in forum Johnson Evinrude Outboard Archive
    Last Post: 07-26-2006, 11:35 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
