Results 1 to 10 of 10
  1. #1
    Talking Checking out a generator
    Does anyone know how to check out a used generator for a 1962 Evinrude 40 h.p. motor that it charges? I have a motor w/o the generator, but have found one off another motor, but have no history of it. The generator is a RK-24L.
  2. #2
    Join Date
    Dec 2015
    Location
    maplevalley WA
    Posts
    4,933
    Default Re: Checking out a generator
    You can run it like a starter motor just ground out the field terminal and apply pos to the armature the motor should spin. Just to be clear run a jumper wire from ground to the field terminal ground the chassis and touch battery pos to the arm post.
    It takes a nickle to go first class!
    If it aint broke dont fix it!!
  3. #3
    Join Date
    Feb 2001
    Location
    Central West Florida
    Posts
    14,514
    Hook up a volt meter to the two posts of the generator.
    Also run a jumper wire from the "Field" post to a ground anywhere on the generator
    Hold the pulley against a wire wheel of a bench grinder so that the pulley turns in the proper direction.
    Observe the volt meter... it should peg the meter at 12v or more.
    We occasionally have questions. If you fail to answer, it may affect ours.
  4. #4
    Join Date
    Dec 2015
    Location
    maplevalley WA
    Posts
    4,933
    Quote Originally Posted by joereeves View Post
    I`m not sure if that test will work if the generator is not polarized first? By using a battery that will polarize the generator at the same time.
  5. #5
    Join Date
    Feb 2001
    Location
    Posts
    14,514
    Quote Originally Posted by kimcrwbr1 View Post
    Kim.... Something I've done many times, yeah it works as long as the field is grounded.
  6. #6
    Join Date
    Apr 2010
    Posts
    4,255
    Is this generator considered an "A" type or "B" type circuit generator ??
  7. #7
    Join Date
    Nov 2011
    Posts
    1,929
    It is an "A" field type. 10 AMP
  8. #8
    Join Date
    Apr 2010
    Posts
    4,255
    What's the difference between "A" and "B" ??
  9. #9
    Join Date
    Nov 2011
    Posts
    1,929
    The field coils circuit. "A" field is externally grounded by the regulator. "B" field is internally grounded and takes a different kind of regulator.
  10. #10
    Join Date
    Apr 2010
    Posts
    4,255
    Thank you fdrgator.
Similar Threads
  1. Just Checking in
    By tripehound in forum Test posting of messages, photos and formatting
    Last Post: 04-20-2010, 08:51 PM
  2. Just checking in
    By smchaplin in forum Mercruiser Sterndrive Archive
    Last Post: 09-11-2009, 12:54 PM
  3. Checking Ujoints
    By rickt in forum Mercruiser Sterndrive Archive
    Last Post: 08-31-2009, 04:34 PM
  4. Checking the alternater
    By cjk23 in forum Volvo Penta Gas Archive
    Last Post: 07-12-2009, 07:36 PM
  5. Diode checking
    By bluzintx1 in forum Johnson Evinrude Outboard Archive
    Last Post: 06-24-2007, 10:30 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
