Results 1 to 6 of 6
  1. #1
    Default 1996 javelin 389 jonhson 175 sudden loss of power
    Sat i was running to next fishing spot and crossed over some choppy waters at 50mph when i suddenly lost power. Yhought maybe something came loose so i checked wires and plugs. No luck. It fires right up and idles fine but when put in gear and apply power is just boggs dwn. Its a 96 javelin bass boat with johnson faststrike 175. Always runs good and this is first issue ive had. It never overheated either. Shifts fine both ways as well. So yesterday i checked everything i can think of. No cracks leaks or any visual problems. Im totally stumped. Any ideas or suggestions on what else to check would be great.
  2. #2
    Join Date
    Nov 2011
    Location
    tennessee
    Posts
    2,713
    Default Re: 1996 javelin 389 jonhson 175 sudden loss of power
    Shift interrupter switch stuck?
    Pappys Sales and Service
    Owner and Factory Certified Technician
    Former racer KDBA (Kentucky Drag Boat Association)
  3. #3
    Not sure never heard of it. Where would it be located at?
  4. #4
    I did the spart gap test and found one cylinder had no spark, ordered new coil. Checked compression on all cyl and 100-110 on all 6. Hope this is it. Just surprised that it wouldnt have any power except at idle with only 1 cyl dwn.
  5. #5
    Ok...got new coil in today and now No spark on btm 2 clyinders. Swapped out a coil that i know wrks and still nothing. What would cause only 2 clynders to not fire? Does anyone have a link for a wiring diagram on the coil system?
  6. #6
    Join Date
    Apr 2010
    Posts
    3,784
    Go to cdielectronics.com for ignition troubleshooting.
Similar Threads
  1. J100TRLCS, sudden loss of power while cruising at 3000 rpm
    By thomcheek in forum Johnson Evinrude Outboard Forum
    Last Post: 06-25-2015, 06:29 PM
  2. 1983 OMC 2.5L 120 HP sudden loss of power Please help!!!
    By jhawley601 in forum OMC Sterndrive and Inboard Forum
    Last Post: 05-19-2015, 07:20 AM
  3. Merc sudden loss of power
    By Colon in forum Mercury Mariner Outboard Forum
    Last Post: 05-11-2015, 09:11 AM
  4. Sudden power loss 60hp Johnson
    By 69boo307 in forum Johnson Evinrude Outboard Archive
    Last Post: 01-12-2009, 06:06 PM
  5. Force 120 loss of power and sudden RPM jump
    By Greg Cordle in forum Chrysler Force Outboard Archive
    Last Post: 11-02-2007, 10:48 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
