Results 1 to 6 of 6
  1. #1
    Default 2004 Johnson 115hp bombarded
    Can anyone tell me the shift rod measurement is from the surface of the lower to the hole in the shift rod the model no is J115pxsor please help a brickies turned home boat mechanic
  2. #2
    Join Date
    Nov 2005
    Location
    Mt. Zion, Illinois,
    Posts
    560
    Default Re: 2004 Johnson 115hp bombarded
    The shift rod measurement is from the surface of the lower unit that mates with the mid-section to the center of the hole in the rod. I just went through this ordeal on my '96 Evinrude 150.
    I would strongly encourage you to make a tool for measuring the height. I used a piece of 3/4"x3/4" angle steel that was about 3/32" thick. The piece was square on both ends so it set cleanly on the LU, I measured my exact shift rod height, drilled a 3/16" hole at that location, then secured a 3" #8 machine screw into place with a nut and lock washer.
    This tool allowed me to hold it perfectly parallel to the shift rod and thread it in and out until I had the screw precisely in the middle of the hole. The length of the 3" screw allows the bottom of the tool to set out away from the water pump.
    KJ
  3. #3
    Quote Originally Posted by kevinj View Post
    KJ
    Can you tell me the measurements mine would be
  4. #4
    Join Date
    Feb 2001
    Location
    Central West Florida
    Posts
    14,282
    J115PXSOR
    Having NOT kept up with the model number coding, a curious question here.
    Would the year coding be SO (2005) with the "R" being a factory run number, or OR (2004) as indicated by Bowie1980?
    If "OR"....... PXS = ?
    We occasionally have questions. If you fail to answer, it may affect ours.
  5. #5
    Join Date
    Nov 2005
    Location
    Mt. Zion, Illinois,
    Posts
    560
    Quote Originally Posted by Bowie1980 View Post
    I don't know. Mine was 21 1/4" but the length has varied among models, years, etc.
    I found this old thread but it doesn't list the 2004 engine. I would assume since you have a Johnson that it's carb'd and not an Etec engine?
    http://www.marineengine.com/boat-for...olved-115-2003
    According to JWMarine's post in that thread it looks like yours might be 21 1/4", but I can't say for sure. Someone with 2004 factory service manual will have to look up the exact value to be absolutely sure.
    KJ
  6. #6
    Join Date
    Aug 2008
    Location
    Mims, FL, USA
    Posts
    1,636
    Quote Originally Posted by joereeves View Post
    J115PXSOR
    "SO" = 2005.
    "PX" = P, power trim and tilt, X, 25" lower unit
    That would make his shift rod height at least 25", or surely not the 21 1/4" referenced above.
    If that 21 1/4" length is right for the 20" engine, then for the 25" engine I would be expecting 26 1/4".
Similar Threads
  1. 2004 115hp Optimax Not Topping Out
    By BarelyAClue in forum Mercury Mariner Outboard Forum
    Last Post: 06-16-2015, 12:54 PM
  2. 2004 115hp 2+2 wont run on 4
    By Big Brown in forum Mercury Mariner Outboard Forum
    Last Post: 08-31-2011, 09:18 PM
  3. 2004 115hp Optimax
    By blair_brad in forum Mercury Mariner Outboard Forum
    Last Post: 03-31-2010, 11:52 AM
  4. 2004 Johnson 115hp lower unit
    By shiner in forum Johnson Evinrude Outboard Archive
    Last Post: 04-18-2009, 10:16 PM
  5. Mariner 115hp 2004
    By sayed in forum Mercury Mariner Outboard Archive
    Last Post: 04-12-2009, 12:25 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
