Click for Volvo Penta parts and manuals!
Results 1 to 5 of 5
Thread: omc compatible
  1. #1
    Default omc compatible
    hello. i have an opportunity to buy 93 chaperell with a 5.7 Volvo penta. the lower unit needs to be replaced. i have a 1989 vip with 5.0 omc cobra. my question is can i take the omc lower unit and put it on the Volvo penta?
  2. #2
    Join Date
    Sep 2010
    Location
    Jersey Shore
    Posts
    4,836
    Default Re: omc compatible
    Why would you do that? OMC is junk. Get a VP lower.
    Chris
    Dockside Marine Services
    Jersey Shore.
    Mercruiser/Mercury Certified
    Let the insanity begin.
  3. #3
    Quote Originally Posted by Docksidemarineservices View Post
    I already own the omc and the lower unit was recently rebuilt now the vip needs the transom redone
  4. #4
    Join Date
    Mar 2009
    Location
    Portland, Oregon,
    Posts
    9,806
    I agree with Chris!
    Note:
    1993 would be OMC ..... 1994 would be Volvo Penta.
    Unless the 1993 OMC is a Cone Clutch King Cobra, it will use Dog Clutch engagement.
    Dog Clutch gear selection occurs in the lower unit.
    Cone Clutch gear selection occurs in the upper unit.
    As you can see, none of these drive components will interchange!
    BTW...... Volvo Penta has never used Dog Clutch engagement!
    Rick ... aka Ricardo..... AQ series Volvo Penta repair
    Portland, Oregon
    28' SDN F/B w/ twin Volvo Penta 5.7L DP's
    Please... no PMs! Post your questions on the forum.
  5. #5
    Join Date
    Jun 2008
    Location
    Island Heights, NJ,
    Posts
    2,791
    re:.... "needs the transom redone" What's wrong with the "transom(shield???? )"? Please note my signature block.... still has original transom shield. I replaced the original 100% OK working drive with a (salvaged from a sunken houseboat) 280 because I wanted the better internals with the higher CID/HP engine.
    Capt Bob
    1969 23ft ChrisCraft Lancer
    Merc 5.7L 260HP/ Volvo 280
    1972 22ft Bristol
    Honda 7.5HP 4 stroke Long shaft
Similar Threads
  1. Compatible to my Chevy omc 350
    By Bigday in forum OMC Sterndrive and Inboard Forum
    Last Post: 07-30-2015, 06:23 AM
  2. 88 3.0 compatible with gen II drive?
    By JimS4 in forum Mercruiser Sterndrive Forum
    Last Post: 05-02-2013, 05:04 AM
  3. 1989 800 compatible with
    By one_wookie in forum OMC Sterndrive and Inboard Forum
    Last Post: 08-16-2009, 04:36 PM
  4. Compatible engine
    By jbell0565 in forum OMC Sterndrive and Inboard Archive
    Last Post: 04-15-2008, 04:38 PM
  5. Is it compatible
    By jonny_5 in forum Johnson Evinrude Outboard Archive
    Last Post: 05-03-2007, 07:09 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
