Click for Volvo Penta parts and manuals!
Results 1 to 2 of 2
  1. Default A little water in oil. Should I run it to heat up the oil before oil change?
    I had a cracked manifold that let a little water in the oil. Should I run it a bit to heat up the oil, or go ahead and change it cold? How many flushings should be sufficient? Do I need to change out the oil filter each time?
  2. #2
    Join Date
    Sep 2010
    Location
    Jersey Shore
    Posts
    4,697
    Default Re: A little water in oil. Should I run it to heat up the oil before oil change?
    Change it until it is clean. Drop the boat in and run it under a load to flash off any water left in the crank case.(this is important)
    Chris
    Dockside Marine Services
    Jersey Shore.
    Mercruiser/Mercury Certified
    Let the insanity begin.
Similar Threads
  1. Water heater -heat exchanger
    By thaley615 in forum Boat Plumbing Systems
    Last Post: 12-21-2015, 10:17 AM
  2. Drain plug at end of heat exchanger leaking water into bilge while in water
    By ruggles in forum Mercruiser Sterndrive Archive
    Last Post: 08-16-2008, 11:50 AM
  3. Heat exchanger water heater ports on a 6V92
    By Drew Harris in forum Detroit Diesel
    Last Post: 08-11-2008, 10:46 PM
  4. Water leaving my heat exchanger
    By coryneil in forum Mercruiser Sterndrive Archive
    Last Post: 02-22-2008, 11:52 PM
  5. Heat exchanger to water pump hose
    By obie8 in forum Volvo Penta Gas Archive
    Last Post: 09-28-2007, 04:30 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
