MercuryMariner
MercuryMariner
MercuryMariner
MercurySierraCDI
Results 1 to 2 of 2
    Default Need Help 99 merc 200hp EFI trouble getting on plane
    Eng]ne is a 99 Mercury 200hp EFI. Long story short I was having issues getting on plane. Ideled fine, and once on plane runs how it should, just took very long to get on plane. Put in new plugs to be safe. Thought it was fuel related, so check my high pressure fuel pump which is at 35psi. So I ruled that out. Drained vst and was good clean fuel. Ruled out bad gas or bad lines which they shouldn't be because they were replaced alittle over a year ago. I thought maybe injectors but it ran to good once on plane so I didnt think that's it. Well I did a compression test and come to find out my #2 cylinder only has 90psi. Took off head's to see what's going on and what I find is in the picture. A Grove in the cylinder wall. It looks like a ring came loose and the piston ate it. I'm guessing this is the reason for my power loss but not positive if this little Grove will have that big of an impact. If so what are my options since I don't have $6500 laying around for a marina to rebuild my engine. What options do I have to get this running the way it should? Will this Grove cause that big of a power loss or do you guys still think I have an injecter issue also? Thanks in advanceClick image for larger version.
ID:	16529Click image for larger version.
    Nov 2011
    tennessee
    2,655
    Default Re: Need Help 99 merc 200hp EFI trouble getting on plane
    It's lost a locating pin and ring broke......tear down time.
    Pappys Sales and Service
    Owner and Factory Certified Technician
    Former racer KDBA (Kentucky Drag Boat Association)
  1. Vindicator 200hp won't plane
    By dgreenlee28 in forum Johnson Evinrude Outboard Forum
    Last Post: 02-19-2017, 11:53 PM
  2. 1983' 200hp merc, idle trouble
    By cydaddy06 in forum Mercury Mariner Outboard Forum
    Last Post: 08-15-2010, 11:14 AM
  3. Lower unit 1984 200hp Merc trouble
    By ChocolateBayouGator in forum Mercury Mariner Outboard Forum
    Last Post: 08-06-2010, 07:13 PM
  4. 74 Merc trouble getting on plane
    By Dave M in forum Mercruiser Sterndrive Archive
    Last Post: 08-15-2007, 09:55 AM
  5. Trouble getting on plane cavitation plate 50mm too low
    By downunderdave in forum Mercury Mariner Outboard Archive
    Last Post: 07-10-2006, 11:47 PM
