MercuryMariner
MercuryMariner
MercuryMariner
MercurySierraCDI
Results 1 to 3 of 3
  1. #1
    Default remote cable installation
    Do both cables need to be channeled between the diamond shaped 1" x 2" piece, and the (apparent) barrel pocket holder attached behind it?
    Is the diamond shaped alloy movable, so that I can run the cables through that finger-width gap?
    This obstruction is 2" back from the cables' rubber seal, at the 60 hp ELPTO's base.
    Thanks for your advice.
  2. #2
    Default Re: remote cable installation
    Quote Originally Posted by flamecensor View Post
    Removing 2 bolts holding the barrel pockets assembly to the engine base let me see that the 'diamond' shaped piece could be rotated clockwise from port side perspective.
    Now I'm sure I can attach the cables.
  3. #3
    Join Date
    Sep 2003
    Location
    New Tripoli, PA, USA!
    Posts
    15,652
    Right; the top hole is slotted so the 'diamond shaped piece' can be rotated out of the way for the cables to be installed.
    Warning! This design, and the one that angles out of the way, need to be zip tied in place. Why? So they can't pop open on you. Imagine screaming along at WOT and having the throttle cable jump out!
    Jeff
Similar Threads
  1. Installation of remote 9.8HP Tohatsu new, question
    By daniel4616 in forum Nissan Tohatsu Outboard Forum
    Last Post: 07-21-2015, 05:27 AM
  2. Cobra Shift Cable Installation
    By Adam Murphy in forum OMC Sterndrive and Inboard Forum
    Last Post: 04-02-2014, 11:27 PM
  3. Need BF15 Remote Control Installation Box Install Guide
    By mileskb in forum Honda Outboard Forum
    Last Post: 03-14-2010, 03:23 PM
  4. Steering Cable Installation
    By dofunny in forum Johnson Evinrude Outboard Archive
    Last Post: 06-06-2008, 11:38 AM
  5. 105 control cable installation
    By odie in forum Chrysler Force Outboard Archive
    Last Post: 11-06-2006, 02:05 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
