Click for Suzuki Manuals, Parts and Model Guides!
Results 1 to 6 of 6
Thread: low compression
  1. #1
    Default low compression
    Hi. I've recently purchased a suzuki dt55 longshaft outboard motor and had it serviced to find out it has low compression in one cylinder. I was told it wasn't worth doing. Any advice on saving it.
  2. #2
    Join Date
    Sep 2010
    Location
    ontario
    Posts
    14,940
    Default Re: low compression
    Maybe check for blown head gasket.
  3. #3
    Thanks racer one. I'm just trying to get a few stubborn bolts out. I might have to strip it down more to get the head gasket off. Also there was no tag on the engine when I got it and I have no indication of how old or what exactly model the engine is. The only tell tale is the tilt and trim is outside the mounting bracket which means it's around early 80s. Any other way of knowing the model so I can order the right gasket
  4. #4
    Join Date
    Aug 2017
    Location
    South Africa
    Posts
    133
    Post a pic, I will tell you what model it is ...
  5. #5
    Quote Originally Posted by deejaycee_2000 View Post
    Can't figure out how to send a pic I'm new to this. I got the head off and good news. The gasket was bad but the cylinders and pistons were perfect. It was losing compression through the water cooling chamber. There's a slight bit of water damage on the head like erosion so I'm gonna have it skimmed to take it back away from the water cooling channel. Any advice on how to fill the hole. It's over a millimetre deep at most so not sure if skimming will get rid of it all I doubt it will. I sheared a four bolts in the process so any tips on how to get theverything out would be good too. Two of the bolts sheared off up close to the block but two are sticking out a bit so maybe not so bad. I'm putting wd40 spray on them regularly as I can before I do anything with them. How do I send a few pics. Thanks, Richard
  6. #6
    Join Date
    Aug 2017
    Location
    South Africa
    Posts
    133
    You can weld it up, but you need someone that knows how to weld aluminium .... epoxy will be a quick fix but won't last all that long ... the 2 bolts that are sticking out you can remove with alot of heat and patients .... the other 2 you will have to drill out and re-tap .... to post pics you have to reply "go advance" and then manage attachments to upload you rpic.
Similar Threads
  1. 70 hp 2 stroke, low compression/water in compression chamber
    By chippydiesel in forum Yamaha Outboard Forum
    Last Post: 02-24-2014, 06:50 PM
  2. Compression probs. Had compression and now none? 1957 10hp
    By newbe25 in forum Johnson Evinrude Outboard Forum
    Last Post: 05-07-2010, 12:02 PM
  3. Compression
    By redsnapper386 in forum Mercruiser Sterndrive Archive
    Last Post: 01-01-2009, 09:48 PM
  4. What should compression be
    By Dewayne Galloway in forum OMC Sterndrive and Inboard Archive
    Last Post: 08-12-2008, 07:57 PM
  5. 57L low compression
    By ray_ray in forum Mercruiser Sterndrive Archive
    Last Post: 12-12-2006, 07:41 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
