Results 1 to 5 of 5
  1. #1
    Default Yamaha 40xwt Aus model How does this correspond to US Model??? Will this US trim tilt motor work????
    40xwt serial 1022854 66TK N
    http://cgi.ebay.com/ebaymotors/ws/eB...m=302341262551
    I am trying to find out whether this trim tilt that looks the same,, well the mounting points look the same will fit.
    Unfortunately they are not nice enough to respond with bolt width,, shaft size and teath etc!!
    There are no Australian Microfische's online or anything on a search to indicate what US model this motor is..
    The Motor is probably 2006-2007 model + (No later than 2009/2010 from when I purchased as a 1 year old engine)..
    the vin seems to be dated after the letter year nomenclature.
    Any help out there?????
    Michael.
  2. #2
    Default Re: Yamaha 40xwt Aus model How does this correspond to US Model??? Will this US trim tilt motor work
    A pdf I downloaded from japanske2015.pdf has the xwt as a 2010 only year model
    40XWT from :2000 to: 2000 Rings part no: REC66T-11603-00 Piston part no: REC66T-11631-01K
    So looks like it must be 2010
  3. #3
    I emailed Yamaha Aust they gave the below response and included parts diagrams from 2005 for a 40XWTL
    2 65W-43880-00 MOTOR ASSY 1 being the part No.... That doesn't seem to help and doesn't coincide with US Model part number, so it seems they use different part numbers, maybe the same part??????
    The US model is here so assuming the first two numbers mean nothing?????
    67C-43880-00-00, 67C-43880-01, 67C-43880-01-00
    67C438800000, 67C4388001, 67C438800100
    Hi Michael,
    We have attached parts diagram for the trim motor assembly.
    Supersession Part number, Item 2 - Motor Assembly is 65W-43880-01.
    Unfortunately, there is no equivalent year model in the US due to the
    introduction of legislated EPA regulations around this period.
    Hope this helps.
    Kind Regards,
    Technical Support Officer (Marine)
    YAMAHA MOTOR AUSTRALIA
  4. #4
    If I search for
    65W-43880-00
    on ebay I come up with a number of listings that give interchangeability between the US and Aus model part number.
    Mike.
  5. #5
    hopefully this will help someone else one day for Australian model yamaha outboard trim tilt motor interchangeability alternate compatible aftermarket yamaha trim motor 40hp 30hp
Similar Threads
  1. Yamaha 50TLR tilt/trim has power but doesn't work
    By Tlongsoga in forum Yamaha Outboard Forum
    Last Post: 06-11-2015, 10:42 AM
  2. Yamaha model 703 control unit tilt/trim switch replacement
    By lander12 in forum Yamaha Outboard Forum
    Last Post: 04-16-2015, 09:45 AM
  3. HELP - Yamaha 40hp 2 stroke trim and tilt 2005 model
    By Garryb in forum Yamaha Outboard Forum
    Last Post: 10-23-2011, 07:43 AM
  4. old model tilt and trim rams
    By bass_tracker in forum Mercury Mariner Outboard Forum
    Last Post: 11-03-2010, 10:55 PM
  5. Trim tilt 70 hp model vj70tlets johnson
    By james dolney in forum Johnson Evinrude Outboard Archive
    Last Post: 07-11-2008, 10:56 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
