Click for Nissan Tohatsu Manuals, and Parts!
Results 1 to 4 of 4
  1. #1
    Default Tohatsu 6 HP starts then stops
    I last ran my 2010 Tohatsu MFS 6B outboard in May. At that time I ran all the fuel out. I pulled it out last weekend to start it and it started right up, ran for a couple of minutes then died. I started it again and it ran for 10 seconds or so and died. It did this several times then would not start at all. (I AM USING FRESH GAS.) Today I pulled it out again and it started right up and ran for a few minutes but only with the choke out. If I put the choke in it would sputter. It finally quit and would not start again. I took the carb off and took it apart. The bowl was clean with no residue. I did notice that when I turned it upside down and blew through the gas inlet I got a lot of resistance--like it was clogged. I took the float and the valve off and I cleaned out the line using a bread tie wrap (someone suggested that) and then blew compressed air through the inlet. It never felt like I was getting a lot of air through the line. ANyway I put it all back together and still no start. So I loosened the drain screw for the bowl and there was fuel in the bowl. Any suggestions on what to do next?
  2. #2
    Join Date
    Mar 2010
    Location
    Buffalo, NY, USA
    Posts
    2,213
    Default Re: Tohatsu 6 HP starts then stops
    Most likely a fuel issue, so my first reaction is to clean the carb. Never push anything through any carb passages. Of course the fuel inlet didn't flow when inverted; that's when the float valve is closed. Of course, check for spark, etc. What does the plug look like?
    Paul
    Buffalo NY USA
  3. #3
    Paul, thanks for your reply. I cleaned the the carb and put a new spark plug in and it started up. I was wrong when I said I inverted the carb and air would not flow through it. It would not flow in its normal position. I am surprised that when you do the proper long term storage procedures you can still get a gummed up carb. Anyway, all is well now and again thanks for your reply.
  4. #4
    Join Date
    Mar 2010
    Location
    Buffalo, NY, USA
    Posts
    2,213
    Yep; it all depends on the fuel you were running. Most US fuels are pretty dirty these days.
    Paul
    Buffalo NY USA
Similar Threads
  1. nissan outboard starts then stops
    By bmason1031 in forum Nissan Tohatsu Outboard Forum
    Last Post: 04-05-2017, 07:06 AM
  2. Replies: 4
    Last Post: 08-15-2014, 11:47 AM
  3. 5 hp 2 stroke tohatsu starts but quickly stops
    By bamaboy in forum Nissan Tohatsu Outboard Archive
    Last Post: 10-14-2008, 08:54 AM
  4. Kohler Gen Starts then Stops
    By richie in forum Miscellaneous marine engine topics
    Last Post: 08-18-2008, 07:56 PM
  5. MAR 8HP Starts on 1st try stops after 40sec won%60t start again
    By Brian Portelli in forum Mercury Mariner Outboard Archive
    Last Post: 01-23-2006, 02:54 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
