Click for Nissan Tohatsu Manuals, and Parts!
Results 1 to 4 of 4
  1. #1
    Default Tohatsu MFS 20C Compression
    Anyone knows what the compression should be in psi for a tohatsu 20 hp 4 stroke? Model MFS 20C, THANKS
  2. #2
    Join Date
    Mar 2010
    Location
    Buffalo, NY, USA
    Posts
    2,213
    Default Re: Tohatsu MFS 20C Compression
    With or without decompression?
    Paul
    Buffalo NY USA
  3. #3
    Quote Originally Posted by pvanv View Post
    I don't know what you mean, I tested mine, (two cylinders), with gauge instead of sparkplug, cold engine, and electric ignition, carburetor empty from fuel.
  4. #4
    Join Date
    Mar 2010
    Location
    Buffalo, NY, USA
    Posts
    2,213
    Tohatsu 4-strokes have decompression that reduces the cranking effort; Once running at say 1000 RPM, the decompression is off.
    What numbers did you get? Was the carb wide open (It should be), and if using electric starter, crank until you get the highest number.
    Paul
    Buffalo NY USA
Similar Threads
  1. New Tohatsu tach in a new Tohatsu 30 hp doesn't work!!
    By firetiger in forum Nissan Tohatsu Outboard Forum
    Last Post: 11-20-2013, 05:53 AM
  2. Compression probs. Had compression and now none? 1957 10hp
    By newbe25 in forum Johnson Evinrude Outboard Forum
    Last Post: 05-07-2010, 12:02 PM
  3. Tohatsu Compression Test
    By jackfish in forum Nissan Tohatsu Outboard Forum
    Last Post: 03-18-2010, 10:37 PM
  4. Tohatsu m50d compression question 95 model
    By sam_digital in forum Nissan Tohatsu Outboard Forum
    Last Post: 01-18-2010, 12:46 PM
  5. 1996 Tohatsu 30HP Factory Compression Specs
    By crappiedog in forum Nissan Tohatsu Outboard Archive
    Last Post: 06-13-2008, 01:33 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
