Click for Honda Manuals, Parts and Model Guides!
Results 1 to 10 of 10
  1. #1
    Join Date
    Aug 2009
    Location
    Malta
    Posts
    121
    Default Honda Bf 90 d engine block removal
    hi i need to remove the engine block as i found water in the flywheel compartment. i would like to know which gasket and if needed seals i have to buy.
    my outboard serial no is BBCJ-1015983.
    thanks Jason
  2. #2
    Join Date
    Sep 2010
    Location
    ontario
    Posts
    14,945
    Default Re: Honda Bf 90 d engine block removal
    That is a big job.----I believe you start with removal of the lower unit and work your way up.
  3. #3
    Join Date
    Nov 2009
    Location
    temecula, ca., usa
    Posts
    2,865
    When you say "water in the flywheel compartment" do you mean just immediately up under the flywheel itself or throughout the entire engine compartment under the removable hood?
    Do you know exactly where the water is coming from? There is a large sealing bolt with oring at the top end of the block. It would be a shame to go through all that bother if it's something simple like that. See items #1 & 2 in the link below.
    http://www.boats.net/parts/search/Ho...OCK/parts.html
    In this same illustration there is the thermostat, it's cover and seal. Another place to inspect for cooling water leakage prior to tearing everything apart.
    Not trying to flame you, just trying to understand the issue you're having.
  4. #4
    Join Date
    Aug 2009
    Location
    Malta
    Posts
    121
    No it is not a water leak that course water to enter in the flywheel compartment but it was till tale pipe that got stuck and full filled the under cowling with salt water and water entered in there i have sprayed a lot of penetrating oil from where there is the starter motor i decided to remove the engine block to check for flywheel corrosion. What do you think shal i take the engine of or respray another lot of penetrating oil??
  5. #5
    Join Date
    Sep 2010
    Location
    ontario
    Posts
    14,945
    Possibly a plug on the bottom of the block is leaking into the flywheel compartment.
  6. #6
    Join Date
    Nov 2009
    Location
    temecula, ca., usa
    Posts
    2,865
    I would hit it with some "SaltAway" or a white vinegar and water solution to make sure that most of the salt crystals are neutralized.
    Then hit it with your penetrating oil again and then wipe up as much of it as you can.
    If you have compressed air, use it to dry out all the nooks and crannies like up under the flywheel.
    If you know what you're doing, you can remove the flywheel to make sure you get everything clean and dry up under there.
    But, if you don't have the puller or have never done it before, just use the compressed air and keep it simple. It should clean up well enough that way.
    WAY, WAY better than taking the engine apart!
    Good luck and let us know how it turns out.
  7. #7
    Join Date
    Nov 2009
    Location
    temecula, ca., usa
    Posts
    2,865
    On second thought, you may not even need a puller to remove the flywheel on that engine.
    Just make dang sure you get the timing RIGHT when you go back together if you do decide to take the flywheel off.
    If you don't have a shop manual, mark the belt and pulleys before you loosen anything up.
    Happy wrenching!
  8. #8
    Join Date
    Aug 2009
    Location
    Malta
    Posts
    121
    as it is a big job first i will remove the starter and take a look with an endoscope camera and if there is no rust i will not remove the engine gust re treat it with same penetrating oli as my only problem is if there could be rusting
  9. #9
    Join Date
    Sep 2010
    Location
    ontario
    Posts
    14,945
    Is the flywheel on top of the engine or underneath on this motor ?
  10. #10
    Join Date
    Aug 2009
    Location
    Malta
    Posts
    121
    no it is the flywheel under the engine
Similar Threads
  1. Anyone knows name or color code for Honda engine block
    By 40honda in forum Honda Outboard Forum
    Last Post: 03-22-2016, 07:28 PM
  2. 1976 9.8hp mercury 110 cilinder block removal?
    By TG.Vollebregt in forum Mercury Mariner Outboard Forum
    Last Post: 05-30-2014, 03:02 PM
  3. 1982 305 cracked block removal
    By rwc in forum Mercruiser Sterndrive Forum
    Last Post: 07-02-2010, 02:52 PM
  4. Honda BF 130 Cracked engine block
    By henge1 in forum Honda Outboard Archive
    Last Post: 10-12-2007, 06:35 AM
  5. Short Block removal
    By Scott Febbo in forum OMC Sterndrive and Inboard Archive
    Last Post: 05-25-2006, 08:48 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
