Results 1 to 5 of 5
    Jun 2017
    Annapolis, MD
    70
    Default mercathode question
    Where does this piece mount?
    Item 1 in the diagram
    I'm having some electrolysis issues with my outdrives and my boat has what I believe is an older version of this part mounted to the transom of the hull just below the water line. does part 1 mount to the transom or to the outdrive?
    Jun 2006
    Spotswood, NJ, USA
    3,819
    Default Re: mercathode question
    the unit mounts to the bottom of the transom housing where the hyd line hoses are.
    Without the correct bonding, it wont help much. Also if there is shore power installed incorrectly or the wrong type of charger installed.
    Jun 2017
    Annapolis, MD
    70
Name:	IMG_1679 this one.jpg
    is this where you mount it? where the anode is?
    I have twin engines...does that mean I should have twin mercathode devices? at present I have one that doesn't seem to be functioning
    is there instruction available for how to install and ensure this is working?
    Jun 2006
    Spotswood, NJ, USA
    3,819
    Yes, you remove that anode and install the mercathode one.http://www.boatfix.com/merc/Techbk/94/94hs7.pdf
    Jun 2017
    Annapolis, MD
    70
  1. Mercathode
    By tuna_man in forum Mercruiser Sterndrive Forum
    Last Post: 03-13-2015, 10:57 AM
  2. MERCATHODE Questions
    By abl1111 in forum Mercruiser Sterndrive Forum
    Last Post: 05-02-2014, 05:16 PM
  3. Mercathode Question for Corrosion Experts
    By 30 Commander in forum Mercruiser Sterndrive Forum
    Last Post: 08-01-2011, 11:10 PM
  4. MERCATHODE INSTALL QUESTION ON 30
    By gizmolvr in forum Mercruiser Sterndrive Forum
    Last Post: 03-26-2010, 01:12 PM
  5. MERCATHODE
    By bobkoss in forum Mercruiser Sterndrive Archive
    Last Post: 02-25-2008, 02:49 AM
